2000 TL Gas Peddle Sticking
Old 12-13-2007, 12:21 AM
8th Gear
dh_6783's Avatar
I just bought a 2000 TL. It has high mileage for the year but runs just fine. The only thing I notice about it is that the gas peddle sticks when I'm starting off from a stopped position. It doesn't stick when I slow down and give it gas only when I stop and go. I called the dealership and they said it might be carbon in the throttle body. Sound correct or any other ideas? Thanks
Old 12-13-2007, 07:06 AM
fsttyms1's Avatar
Received 3,063 Likes on 2,119 Posts
Most likely they are correct. Get yourself some carb cleaner and clean it yourself. It wont take long and is easy to do. If you have an old or cheap tooth brush it will help you scrub it better.
Old 12-13-2007, 11:28 AM
TL-S driver
goldendragon576's Avatar
I have an 02 TL-S and I'm starting to get that to once in a while. It's worst when I don't drive my car for more then a day. What and where do I scrub?
Old 12-13-2007, 02:51 PM
fsttyms1's Avatar
the carbon buildup around and on the butterfly on the TB.
Old 12-13-2007, 07:51 PM
Anachostic's Avatar
I had this happen and it was fixed when I had the $200 fuel system service done at the dealer. If you feel rich...
And it didn't clean out all the carbon because shortly after I had it back in for misfires and that was blamed on carbon buildup.
But I know how you feel. Jackrabbit starts suck for the passenger.
Old 12-13-2007, 09:10 PM
2005 Acura TL
proudacuraownr's Avatar
its most likely the throttle body. but it could be other things to
Old 12-14-2007, 09:32 PM
Rich
Rsoetidjo's Avatar
I had that happent to me twice with my truck.
Just clean the throttle body with the throttle body cleaner
Old 12-14-2007, 11:47 PM
B A N N E D
kushsmoker's Avatar
its probably your throttle body.. I'd probably stick with throttle body cleaner Some carb cleaners shouldnt be used on TBs
Old 12-15-2007, 02:50 PM
No He Can't
6MTUA5's Avatar
fsttyms1 was was probably talking about taking the TB off and cleaning it
Old 12-15-2007, 03:33 PM
I need 2 more gears
sbuswell's Avatar
use some seafoam Deep Creep and spray it in your TB while running your car, then when you shut it off take a shop towel and lightly wipe any excess gunk off. Let your car sit for 10-15mins and then go for a drive hitting WOT a couple of times to blow out all the carbon crap that the seafoam and liquified. You will probably need new plugs as your car probably has a serious amount of carbin buildup and the seafoam will make your plugs dirty.
Old 12-15-2007, 03:54 PM
fsttyms1's Avatar
No need to take it off, it can be done on the car
Old 12-15-2007, 08:24 PM
I need 2 more gears
sbuswell's Avatar
By the way every other time I use seafoam I will use Deep Creep and spray it thrue the TB. The TB on my car is spotless on the inside. You might want to get a good fuel system cleaner while your at it and change your oil with a good syn and you're car will probably run flawlessly.
Old 12-17-2007, 08:53 PM
8th Gear
dh_6783's Avatar
Thanks to everyone that replied. Its a big help.
xsilverhawkx
10-05-2015 11:00 AM
Skirmich
10-01-2015 12:59 PM
Joe Avesyan
09-29-2015 03:57 PM
San Yasin
09-29-2015 10:52 AM
Quick Reply: 2000 TL Gas Peddle Sticking
