P0131 O2 Sensor replaced but still getting code
Old 12-18-2018, 05:24 PM
jimbodude's Avatar
Was getting the p0131 code and changed the o2 sensor. when I changed it, there was oil on the connector. I cleaned the connector with electronic spray and used dielectric lube but it's still throwing the code. I'm pretty sure the oil is coming from my valve cover gasket (will be replacing soon).
1. How long does it take for the code the clear? I only had it at idle and the code didn't go away.
2. Anything else I should try?
Old 12-18-2018, 05:46 PM
Received 8,576 Likes on 6,626 Posts
1. Make sure you use OEM o2's not Bosch
2. You can disconnect the battery to clear the ECU.
Old 12-20-2018, 11:37 AM
jimbodude's Avatar
I got the Denso O2 and cleared the codes via obd2 scanner. Looks like I'm also getting P0135 now. I followed the maintenance manual to troubleshoot and I'm not seeing the 12V come across the heater pins. I'm thinking the wires are bad. Going to trace the wires back to see if they are damaged from the oil.
Old 12-25-2018, 10:38 PM
Arkady's Avatar
Keep us posted! I've got the same codes, but I haven't done anything about it yet as it's way too cold outside haha. I'll use the knowledge you share to make my fix go by quicker : )
Old 01-16-2019, 01:00 PM
jimbodude's Avatar
The sensor I ordered ended up being defective. I ordered another one and it worked fine. Both were Denso. Every is up and running and I passed smog!
Saudade (01-18-2019)
Old 01-18-2019, 12:18 PM
USAF Veteran
Saudade's Avatar
Thanks for posting the follow-up!!
Old 01-20-2019, 07:44 AM
Curious3GTL's Avatar
By any chance did you buy them from Amazon? I had that same issue with an Amazon sensor.
Old 01-20-2019, 10:33 AM
jimbodude's Avatar
The defective one was from ebay. I bought a working one that was from Amazon warehouse that just had a damaged box for $12. Has been working great for 3 weeks now
The following 2 users liked this post by jimbodude:
Curious3GTL (01-20-2019), Saudade (01-20-2019)
Rejckt
09-22-2017 04:12 PM
FreeIsGood
09-14-2017 11:32 AM
dcbakerphoto
2G CL Problems & Fixes
10-24-2016 09:47 AM
Oakroadsteve
09-21-2015 10:50 AM
Quick Reply: P0131 O2 Sensor replaced but still getting code
