Notices
2000 acura tl engine/transmission nuts and bolts
Old 05-02-2019, 01:28 PM
New Member
ok so I made the mistake of not separating the screws and bolts when I took off my transmission and replace it with another one and I'm having a hard time figuring out which bolt goes where and it's really frustrating, I was in such a hurry that I didnt separate them and I'm wondering if theres a diagram or something to know which bolt goes where, if someone has a diagram or something like that to show me where each part goes i would highly appreciate it, thank you very much, also if theres anything i should know about changing transmissions that would be a great help, thanks again
Bradley Gonzalez is offline
Old 05-02-2019, 05:33 PM
Registered Member
whitetiger5's Avatar
The only advice I could give:
if you have a good collection of all the nuts and bolts (meaning you are certain you haven't lost any): there are specific numbers, you can use those numbers in your favor.
In addition; the bolt diagrams in the manual and in the websites to purchase parts show the dimensions of the bolts; if you have a pair of calipers, you could use them to measure a bolt in question to determine if it's the right length for the part you are re-attaching.
Maybe try watching the video of people disassembling the transmission as well.
whitetiger5 is offline
Old 05-02-2019, 05:37 PM
Received 5,925 Likes on 4,754 Posts
https://www.oemacuraparts.com/v-2000...ission-housing
look in here to try and reconcile it.
good luck.
thoiboi is offline
Old 05-02-2019, 09:33 PM
Registered Member
Iggy's Avatar
Bolt dimensions and pictures are in the service manual. click here for dload
Iggy is offline
Rejckt
06-15-2008 06:28 AM
Console & Computer Gaming
05-15-2008 01:26 AM
zoltanh
Second Generation CL Discussion (2000-2003)
05-11-2005 09:23 AM
ronrecr
04-01-2005 05:43 AM
NOMAD
First Generation CL Discussion (1997-1999)
10-24-2002 12:54 PM
Quick Reply: 2000 acura tl engine/transmission nuts and bolts
