06-07 accord trans swap
#441
After the lights came on I just drove home and parked... haven't drive since, I'll bring it to shop tomorrow
#442
Because if it isn't failing and the TQ its doing its job then it doesn't make any sense that its still poping the code..
Resetting the ECU might trigger a different one or might not trigger anything at all. By itself the ECU resets itself in a couple of hours running without any issue and it will turn off the MIL...
P0740 is faulty T/Q Clutch Solenoid but yours is working OK so why its ON?....
#443
#444
Then it only pops when its trying to engage the T/Q at highway speeds... You need to check if its indeed engaging it doesn't make sense its throwing a T/Q Solenoid Code if its working OK.. At 60MPH with T/Q Engaged your RPMs should be in the 1500 area... when you step down half of the accelerator it should disengage and go up to 2000+RPM... This will tell you if its indeed working.
#445
I just dropped off this morning and will call them in early afternoon. keep everyone posted!
#446
I had the same failure code. After I researched this site I decided to do a D&R and prepare for my transmission to die.. I had the same exact symptoms Christmas lights at 60 mph. The transmission completely failed about 2 to 3 weeks later it was very slow to engage all gears and was flaring between shifts. It eventually wouldn't budge. Swap in the AV6 the rest is history. Sounds like the shop has some "xplaining to do". I hope you get this all worked out.
#447
#448
Could be a worn convertor, or possibly a malfunctioning solenoid ?
#450
Update: stopped by the shop and the car was ready, they said they replaced the solenoid sensor, so I took the car for a spin...
This time the car feel like a bit hard to downshift when I step a bit more on gas. anyhow, moving forward, after the car reach 60MPH for like few sec then all lights came back on. so I dropped back off to the shop.
#451
#452
#454
^^ Is that a constant speed or pick up??
Cuz I do a lot of highway speed and I'm absolutely sure you should be riding 1.5K @60mph and 2K at 70mph 2.5K at 80mph < I care for my MPG that much...
By the looks of it you don't have the 500RPM threshold of the TQ Convertor clutch system.
So unless you were picking up speed the RPM is obviously off, Looks like TQ isn't engaged..
Engage Cruise Control in D5 at 60MPH on flat ground and your RPM should stay at 1500RPM..
#456
above is the RPM @ 2K with 60MPH constant when I'm holding the gas on highway. i think by time i get to 70mph my RPM should be at 2.5k. if my TQ convertor is not engaged.. you think engine light will come on?
#457
2k at 60 is normal, remember the av6 trans has a shorter 4th and 5th gear
#458
Yeah, as 666Wokker said about the AV6 gearing.
The RPM's on the donor AV6 seem to run a bit higher than the original trannys at the same speed.
#459
Thanks guys! phew. Accord tranny on my TL. woot woot!
Here's my review so far...
It does drive good and shift from 1st gear to 2nd gear which a lot smoother but from 2nd to 3rd not that smooth but still great. overall on highway when I need to speed up the car did not need to downshift which it's a plus, i like the power in same gear.
#462
FYI: TL-S and AV6 Trans have EXACTLY the Same gearing..
Only TL-p Transmission should see a different rating
So I can compare my TL-S transmission and AV6 equally.
1.5K for 60MPH is the Normal for Cruise driving..
Bear in Mind I do 80% Highway with my TL So I'm pretty OCD with these things.
His TQ Isn't engaging...
Yah had to happend those 500RPMs where all my Hint... Got the Codes? P0740 again?
#463
I haven't get a chance to scan the code yet, I'm planning just bring it in and let them take care of it. I'm thinking to tell them just put the Acura transmission back. it's getting annoying....
#464
^ Seems weird you are having this problem as your not the first to do the swap I haven't seen that issue so many times in any other thread... Seems they are doing something wrong.
I would not advice you to put your old one back.. That code isn't in any scenario a Swap Killer and you are getting it constant so its your only issue left.
#465
Have you asked them how they handled the torque converter with the latest transmission? Is it new or is it the same one from the last TL transmission that failed??? It is the only possible common link from the one swap to the next since they tested the sensors. If you don't bring it up they probably won't either since it involves dropping the transmission again. I've thrown this out there a couple of times..
#467
7th Gear
My 03 tl type s is sick
Hey what's up guys,
So I'm reading on this article and really want to get this av6 transmission. My car currently has 178,000+ and my transmission slips and shift super hard. Then after awhile it won't go over 20mph. I live in nyc so where can I get this transmission at and where can I get this job done.
#468
Hey JDM_DoMo87, you can try the "Regions" sub-forum for other members in your local vicinity. Living in NYC, you should have several shops who could possibly do the "AV6" donor replacement installation for your TL's old ailing tranny. Check with friends, neighbors, yellow pages, etc.
When you talk to the shops, simply ask them if they would be willing to bolt-in a direct replacement for your sick tranny. Don't tell them that it's a swap. Start looking for a donor "AV6" tranny, which is an updated version of our original 5 speed AT. This "AV6" will come from a '06>'07 Honda Accord V-6 model. Figure less than $1000 for the tranny and about $500 labor to install it.
#470
^^^ Also, when looking for a donor AV6 ....... check some of the local auto salvage recycler's.
These guys have connections, and may be able to do the installation or refer you to someone who could.
Good luck in your search !!!
#472
I think this is a moot point since the swap is so easy. I took mine to a redneck shop in downtown Indy out here and they didn't even know what an Acura was. They got it when I told them it was a Honda. They'd obviously never worked on one. Swap turned out fine thanks to the diagrams and info I found and put on here along with everyone else. Swap is simple just make sure the shop has done tranny's but they don't necessarily need experience with Honda's.
#474
So today I finally received the bad news about my 02 Acura TL's transmission (130k mi) :c .. Apparently it is starting to show signs of the trans. wearing out, and the shop recommended I go ahead and rebuilt it now before I get stuck on the road somewhere.
At this point I'm not sure if I want to rebuild or go ahead and try this swap out. The owner tried to convince me that rebuilding is just as good if not better since I'll have new parts installed. I got quoted $1400 for a full rebuild including labor of course.
What do you guys think I should do? I don't really want to read through this whole thread, but to those that didn't opt to rebuilding and opted to go this direction instead, was it worth? No offense to jzhu625, but that is exactly what I want to avoid, is having issued afterwards and having to take the car back to the shop. Ain't nobody got time for that.
#475
#476
'02 TL @ 130k.....tranny issues
So today I finally received the bad news about my 02 Acura TL's transmission (130k mi) :c .. Apparently it is starting to show signs of the trans. wearing out, and the shop recommended I go ahead and rebuilt it now before I get stuck on the road somewhere. The owner tried to convince me that rebuilding is just as good if not better since I'll have new parts installed. I got quoted $1400 for a full rebuild including labor of course, what I want to avoid, is having issued afterwards and having to take the car back to the shop. Ain't nobody got time for that.
Hey Jdmitr03, what are the actual problems which you're presently experiencing ?
~Has the tranny been ever replaced before ?
~Has the fluid been replaced ?
~Are there any CEL codes or flashing "D5" ?
~Have the motor mounts been checked ?
IMO, I'd get a second evaluation of the tranny, if uncertain of it's condition. Don't feel pressured to have work done unless you're certain that there's a seroius problem. The $1400 quote seems reasonable, but is the shop experienced with Honda tranny's and what is their warranty on the rebuild ?
#477
Technician said there are two "jerks" when going from Reverse to Drive, which he said are signs of a transmission starting to go bad. I have not paid attention or noticed said "jerks", but I do know that the car does take a while now for the car to get into gear when I go from R to D (not sure if this is normal?).
~Has the tranny been ever replaced before ? No sir, still on original trans.
~Has the fluid been replaced ? Fluid was replaced back in 2011 at the dealer.
~Are there any CEL codes or flashing "D5" ? No codes or flashing D5.
~Have the motor mounts been checked ? Yes, all were good still when checked in Jan.
#478
If the tranny shop told ya that the car is still "driveable" for another year, than just drive it.......or sell it !!!
But seriously, don't rush into things until you're sure that the tranny is actually going bad. In the meantime, study your options....check out the "AV6" threads for the newer design '06-'07 Honda Accord V-6 tranny as an alternative to rebuilding the original tranny.
#480
Recheck all of the mounts. They can cause tranny jerks. Cheaper to replace than tranny.
Some things to possibly help keep your "iffy" tranny going for another year:
~Do a drain & fill using only Honda DW1 fluid.
~Check the pan's drain plug magnet for residual fines.
~Have a sample of the fluid evaluated.
~Replace the spin-on AT filter.
~Clean the solenoid screens.
