03 Type-S engine swap into 99 TL-P thread
Hello fellow 2G TL owners...Its been a while since I've visted..but it looks like there are some threads I want to check out.
As the title states I've got a 99 TL-P. The engine has near 300,000 miles, it still runs..but eventually I feel the trans will fail.
I have a 2003 TL-S complete parts car, and I wondered exactly what I would have to swap into the TL-P in order for it to run successfully.
Has this been done before?
I've got the original Keys and ECU for both swaps...Im sure I'd have to run the 03 type-s ECU in order for the engine and 5 speed auto trans to function properly, but I'm wondering If I would have to change the Dash harness for any reason? I'm thinking so since TL-P harness to the shift area would be for the 4 speed auto in the 99.
Are there any threads you guys know of related to this? And would it be possible? Searched the DIY, however couldn't find anything related to this topic.
Thanks!! Looking forward to figuring this out!
Why would you feel the Tranny will Fail? 4 Speedo TLers are less prone to Fail than ours POS 5 Speeders....
If you are doing the SWAP do it properly, 6 SPEEDO!.
Not sure if you caught the 300,000 miles part on the current 4 speed J32a1 (currently tends to slip)...I'd be doing the swap since it wouldn't cost anything except for time and a few seals, gaskets etc.
I've already got a CL-S 6 speed so unless a manual transmission and all other parts fell out of the sky, the TL is going to remain an automatic!
So would anything else be necessary in order for it to run correctly?
Always Working In
Therrs another guy on here thats done this. He just had a thread a week or two ago asking about an 03 remote on his 99. He has done the exact same thing. Complete 03 everything in a 99.
Yeah I Noticed the 300K But that doesnt Mean = Crap Transmission.
Our 1987 Pontiac 6000 with 527K its still running on its original 4 Speed Tranmission, On its 3rd Engine (Family Relic dont Ask).
Even if you Have a CL-S 6 Speed, a SWAP is Costly and if you are already on the boat why not do it right? You will spend more Money fixing the stupid 5 spd every 60K then the 6 speed will make much sence...
I dunno man maybe Im biased cuz I hate my 5 Spd but its your call! Good Luck on the Swap!!
Always Working In
https://acurazine.com/forums/2g-tl-1999-2003-98/will-1999-acura-tl-remote-work-2003-tl-828340/
Sorry man. I was at lunch and I forgot to link to the thread.
3.2VtecTL (08-24-2011)
3 pedals in my 99 TL
yeah i noticed the 300k but that doesnt mean = crap transmission.
Our 1987 pontiac 6000 with 527k its still running on its original 4 speed tranmission, on its 3rd engine (family relic dont ask).
Even if you have a cl-s 6 speed, a swap is costly and if you are already on the boat why not do it right? You will spend more money fixing the stupid 5 spd every 60k then the 6 speed will make much sence...
I dunno man maybe im biased cuz i hate my 5 spd but its your call! Good luck on the swap!!
https://acurazine.com/forums/showthread.php?t=828340
Once the 03 TL-S swap is in, the car would probably only be driven about 250 miles if that per month. so therefore it would take years for the 5 speed to malfunction hopefully....if it happens in the future let it be!
I'm looking to swap the (03)J32a2 in to replace the original (99)j32a1...the car will be barely driven once completed just would like it to run errands and short trips around my town.
Back to the subject...Does anyone know if the vehicles mileage is stored in the ECU? I'd like to swap the 03's gauge cluster also so i'm sure I'm going to have to swap the complete dash harness...It would also be convienent if the mileage actually matched the engine/trans which is 150,xxx on the 03 type s swap.
hey have you finish your swap im doing the same but the car only start with the 99 computer and not with 02 type s ecu
i know is the ignition swhitch and keys the computer and the inmobilazer to make it run but the inmobilazer is diferent on the 99 tl
any help please
any help please
You need to have the dealer program the key to the type-s ECU. Its the only way
you think it will work if i swap the dash harness ignition switch with keys ecu and immobilazer from my 02 tl type s is a parts car it was in accident and is not repairable
also any one know if the harness will fit
2000 acura tl FPR
Cluster. All cars I know of store it there. At Honda we were supposed to send the miles of the original so the replacement cluster would read the same as the original.
Have you tried looking up the part numbers on an acura site to compare both years? Swap the parts that aren't the same part number. Give that a shot.
i did and dont start there is another part for the immobilazer i dont remember the name but the 99 is diferent t the 2002 and plugs to the dash harness thats why i was thinking to swap the dash harness if i reprogram the key i have to buy a new imobolazer 3 keys and take it to program thats almost $400 $500
thats why i want to swap all from the 02 tl if is posible
All you have to do is take your car to the dealer and they will REPROGRAM your existing key to the new ECU. It cost me 45 bucks or so to have my Honda dealer do it for me when i swapped to a 6 speed.
There is an immobilizer module right by the ignition. The other part of it is IN the ECU.
01 motor swap with 99 harness
So I've done a swap with the 01p motor with the 4 speed trans motor seems to have alot of hesitation not sure if its getting the correct amount of fuel anyone have any experience with this?
99 tl oval dirt car.
justin7779
12-25-2015 10:33 PM
mugen_kid
11-13-2015 10:38 PM
