Notices
03 TL Type-S external transmission fluid cooler
Old 04-20-2019, 07:51 PM
Registered Member
Sorry if this has been covered , tried search and did not find something on this.
Id like to install an external trans fluid cooler on my 03 Type-S. Where should the lines get hooked up to? Feed or supply line?
Pics would be a huge help.
Dntstp4cops is offline
Old 04-24-2019, 01:31 AM
Registered Member
Sweet now i can tackle this install , mucho help here 🤣
Old 04-24-2019, 02:13 AM
Registered Member
whitetiger5's Avatar
LOL...there are probably few people who have installed it, and even less who have seen it make a difference in the lifespan of their transmission to comment or provide any advice.
If you have the stock transmission, I believe that most will advise you that no matter how good of a cooling system you install, nothing will prolong the life of your transmission as good as 3x3 + spin on filter changes.
However, from the few I have seen: the cooler replaces the small hockey puck shaped cooler on top of the transmission that passes coolant and ATF close by each other to warm up and keep the ATF temp consistent with engine coolant temp.
If it were me...I'd probably look at trying to replace the mount for the warmer with that from the Odyssey, which will accept banjo bolt/piping that leads straight down to the area where you'll be installing the cooler.
whitetiger5 is offline
Mcdoogle1975
Third Generation TL (2004-2008)
06-10-2017 08:55 AM
TavuL
1G & 2G MDX Discussion (2001-2013)
06-25-2012 06:58 PM
nspec_ya4
08-22-2010 06:41 PM
tommyt1777
2G CL Transmission Recall Q & A
12-25-2009 08:38 AM
tommyt1777
Second Generation CL Discussion (2000-2003)
25
12-06-2009 08:02 AM
Quick Reply: 03 TL Type-S external transmission fluid cooler
