03 TL-S Tranny
03 TL-S Tranny
I recently purchased a 2003 TL Type-S with 140k mi. on it. It's only had one owner, and service records show it has been maintained at Acura dealers in MA. Before I drove the car off I did a 3qt drain and fill of DW-1.
It was driving great without issues for the first week of owning it. Soon after, I noticed some slippage in the gears, as well as delays between changing from Park to Reverse or Drive and tranny engagement. I then take the car to inspection (which it passed) and once it's done, I noticed a harsh shudder in shifting when I went from park into D5. I didn't think much about it until I approached a red light, and I slowed down to stop and the car had a hard downshift (something like from 5th to 2nd), and the force felt as if I had gotten rear ended. The car then gave a check engine light and my VSA light and warning symbol lit up (the CEL code was p0730).
Not wanting to drop gears so hard, I drove in 2nd all the way home. The first thing I did was clean out the external solenoid screens on the tranny (I noticed the ground strap was completely corroded, not sure if this is causing electrical issues) and and the car drove well soon after. Everything rode fine until the car fully warmed up; the gears were slipping horribly now and there were thuds between every up-shift and downshift.
I've noticed when cold, the car is fine with engaging into reverse or drive and when in D4/D5 it shifts without hesitation; up until the car is fully warmed up.
I'm not sure what I can go about doing now, since I really love the car but it's just been parked outside since I don't want to kill the tranny for good.
Did you fix the ground strap? That's pretty important.
Have you verified that the fluid level is correct? Should be checked with car fully warmed up, after driving at speed, immediately after shutting off the engine.
civic5133
12-02-2005 08:21 AM
4pumpedCL
04-05-2002 05:49 PM
pnumbra
2G CL Transmission Recall Q & A
04-03-2002 02:19 PM
