03 CL-S6 Flywheel
03 CL-S6 Flywheel
While going through the parts list and checking the high ticket items, I found the flywheel part: 22100-PGE-026.
In the swap builds, most people are listing max ~$400 for clutch and flywheel. Where are you guys finding the manual trans flywheel for that cheap? The cheapest I found was about $500.
Should I just get a used one from car-part.com for ~$150? I'm okay paying $250 for a new oem clutch.
In light of this, I plan on only getting one of these two lightweight products. Would you recommend the light pulley, or the light flywheel?
If I'm using an auto 2G TL engine with a CL-S6 tranny, should I get the CL flywheel or the 3G TL flywheel?
Have you tried going thru napa or carquest, rockauto?, when I did my clutch on my accord, I got a new Flywheel for 70bucks from napa, and clutch kid from carquest for around 70 also.
I miss dirt cheap parts lol.
They are pretty much identical from what i've seen, so whichever can be had for cheaper, go for.
I read that using a light weight flywheel at the same time as a light weight crank pulley will cause problems and damage. There was not enough dampening in the crank, and it caused the pressure plate to become damaged, or something like that?
09-15-2015 06:44 PM
03, 0407, 22100pge026, acura, acurazine, aftermarket, cl, cls, dual, flywheel, lightweight, mass, part, tl, type
