Notices
02 tl stalling after startup
Old 05-30-2019, 08:17 PM
New Member
Iím new to this forum stuff so bear with me...
my 02 tl starts perfectly, idles a little high (1100 rpm), but when you try to accelerate it starts to stumble and attempts to die. But it never dies or throws a check engine code. Iíd relate it to being like a carburetor with a bad accelerator pump. I can pump the gas pedal and get it to move in a jerky fashion or If I just hold the pedal in one spot it tries to die, then accelerates then tries to die. However 30 to 45 seconds of this and it runs perfectly. It does it with the engine hot or cold, and weather appears to have no affect. Ive cleaned idle air control, no change. Iíve tested the tps with my code scanner and it appears to be fine. Iím baffled. It seems to be something in the initial startup phase but I donít know a lot about these cars. This thing has given me 255k of reliable miles and been a great car and I canít let it beat me on the first difficult issue it throws me.
Thanks ahead of time for any help!!
Angry Twizzlers is offline
Old 06-04-2019, 02:12 PM
Registered Member
I've been away from my TL for over a month now so I can't recall the exact name of the thing, but there's a little hole on the lower intake manifold that can get clogged up over time. There's a DIY on this forum about cleaning it out - it's a quick job so see if that does the trick.
Arkady is offline
Old 06-05-2019, 04:35 PM
Registered Member
Silencer_'s Avatar
Maybe it's an o2 sensor? I remember having the same problem. I switched it out and the car ran fine afterwards.
Silencer_ is offline
jojo2112
1G & 2G MDX Discussion (2001-2013)
05-16-2014 09:21 PM
jayn1321
03-22-2011 06:11 PM
MaxMike93
1G CL Problems & Fixes
05-16-2010 12:21 AM
skyline
Second Generation CL Discussion (2000-2003)
14
03-29-2002 01:25 AM
skyline
First Generation CL Discussion (1997-1999)
03-29-2002 12:52 AM
Quick Reply: 02 tl stalling after startup
