02' tl-s tranny problems
Old 04-17-2014, 09:35 PM
AcuraGangg's Avatar
hello guys! my 02 tls is started to form transmission problems, for example there is hesitation from 2nd to 3rd gear. and also sometimes when i put the car in drive the gear stick clicks idk what that is. anyways what transmission would be compatible with my car?
Old 04-17-2014, 09:37 PM
Skirmich's Avatar
Received 1,016 Likes on 867 Posts
Ouch so they sell you a car on its last legs??? If you buy it from a Dealer you should make them fix it for you under warranty..
If you buy it from a Private Seller then your best bet is to Save up for an Accord V6 2006-2007 Transmission which is completely compatible with our car and its a lot more reliable than you current transmission..
What ever you do: DONT REBUILD YOUR CURRENT TRANSMISSION.
AcuraGangg (04-17-2014)
Old 04-17-2014, 09:47 PM
AcuraGangg's Avatar
Alright thanks skirmich youve been a Huge help!
Old 04-18-2014, 07:48 AM
Nicks2001tl's Avatar
Rebuilding your current transmission is hit or miss. If it`s slipping gears you can try changing the fluid doing a 1x3.
Any codes?
Old 04-18-2014, 10:06 AM
AcuraGangg's Avatar
Any codes?
havent taken it to auto parts yet. and can you explain a 3x1?
Old 04-18-2014, 10:13 AM
3.2TLc's Avatar
Check the 2nd Gen's "DIY" sticky for tranny fluid replacement procedures.
The basic 1x3 Drain and Fill is simply draining the tranny's fluid pan reservoir and replenishing with a bit more than 3 Qts. Honda DW1 fluid. Some other simple things to try include replacing the spin on external ATF filter and cleaning the solenoid screens.
AcuraGangg (04-18-2014)
SidhuSaaB
05-30-2020 12:40 AM
Pham Alvan
03-16-2016 09:17 AM
LoneRonin
01-04-2016 01:03 AM
Matthew Purpura
09-25-2015 06:10 PM
Brandle34
09-23-2015 07:20 PM
Quick Reply: 02' tl-s tranny problems
