01 CL-s motor in 99 TL temp guage not working
I just bought this 99 TL with 01 CL-S motor swap for pretty cheap. The temp guage is not working and I need some help to figure it out. I think I've found the wire for the temp sending unit but it is a single wire and there is not a post to plug it on. I found a pic online that shows it connected but mine does not have a sensor there. Pics would help but it won't let me attach any
Only 99 TL the Temp. Sensor on right bottom side of EGR. If your still using 99 engine harness these sure be unplug pigtail by EGR area. When they swap out engine do you know what harness did they use. If you are still using 99 harness then you going have make tap for it. The 99 TL temperate sensor is like Accord an 00-03 TL/CL are wire into engine harness.
Thanks for the replies. I am not sure of the harness used but the wire is right by the egr and the pic I found online its plugged in by egr. On my thermo housing it has a little spot that is about the same size as the sensor but was never cut out from the factory. If anyone has a thermo housing with the sensor already in place I'll buy it
Mine has that sensor and another one like that by the t-stat. There is a single wire that I am talking about that is right behind and to the left of that sensor. I'm not sure how to do the photo bucket thing so I guess I'll have to wait the remainder of my 15 days to post the pics(sucks)
I found a way to show the pic i cant post... here is my honda-tech post with pics
http://honda-tech.com/showthread.php...1#post49585117
Your right about my pic... i just found sometime online help you out an wrong pic...
here your pic...
The arrow point in middle of pic is what we are talking about. I just made tap using old one off my TL an some JB weld an install into new engine. I know you don't have it but not sure how hard get one.. Here some pic of what i did below your...
here your pic...
jareds83 (03-16-2014)
here your pic...
here your pic...
