Notices
Transmission mounts - need some help
Old 03-28-2019, 07:30 PM
Registered Member
Liked 9 Times in 8 Posts
I recently replaced my motor mounts, once that was done there was a vibration coming from the engine that wasn't there before, I had assumed that because the mounts were fixed the transmission mounts were now in need of replacement and taking all the vibration thus causing more vibration than normal.
I bought a transmission mount, front upper for 24.99 with hopes that the more expensive mount was fine.
I got the mount, tore the car apart and for the life of me I can't find the mount. I did however find the lower more expensive mount and it's shot so there is that.
for our car, are there two mounts? I also found a couple other mounts that I have no idea what they are for but seem to be in need of replacement.
Any help would be appreciated.
H8PVMT is offline
Old 03-28-2019, 07:35 PM
Registered Member
Some pics to help
This is right against the sway bar back side under the transmission
I bought this mount, should be front upper but there isnít anything like it around
This is lower left under headlights and battery box, i have no idea what it is or what it does.
Expensive mount broken.
H8PVMT is offline
Old 03-30-2019, 11:49 PM
Registered Member
Iíve searched the car over and over, the mount that I purchased does not go on my car, Iím 100% certain. However, I did find the transmission mount thatís bad. I found a replacement at parts geek for 309 and a 15.00 coupon with free shipping and no tax made it 294.00
here is the old busted mount, makes sense that I was feeling a large vibration.
H8PVMT is offline
Old 04-01-2019, 12:44 PM
Registered Member
Liked 1 Time in 1 Post
Those always break
Those are always busted.
Ali Islam is offline
Old 04-02-2019, 06:50 PM
Registered Member
deepa1600's Avatar
Liked 16 Times in 13 Posts
Mine is also busted, unfortunately it's an expensive endeavor to replace engine mounts on our cars. I also ordered a transmission mount from Amayama.com I paid about 260$ Canadian (195 USD) including shipping, mount, bunch of bolts. Car has about 140k miles.
deepa1600 is offline
Old 04-05-2019, 08:32 AM
projektvertx's Avatar
Liked 511 Times in 414 Posts
It's a Honda mount thing. I'm convinced Honda can't design mounts if their lives depended on it.
projektvertx is offline
The following users liked this post: projektvertx
H8PVMT (04-08-2019)
Old 04-08-2019, 05:11 PM
Registered Member
Against my better judgement I'm taking the car to the dealership to have her looked at and help to determine what is wrong. After replacing all the mounts in the car (3 motor and 1 transmission) I'm still getting a vibration at a stop while in gear. I can't figure it out. I made sure the vacuum lines were hooked up, made sure the mounts were bolted on properly... just no idea. So for 90.00 hopefully they can tell me what is wrong and God willing it's cheap.
H8PVMT is offline
Old 04-11-2019, 12:40 PM
Registered Member
RG08RL's Avatar
Liked 2 Times in 2 Posts
Please let us know the outcome. I'm also experiencing severe vibration at idle after replacing the rear motor mount. The vibrations get really bad between when the speedometer hit 15mph all the way to 30mph, once you pass the 30mph range, the vibrations subside and the car feels good as new. I first replaced the front and side engine mounts last month and I saw a big improvement in the car and didn't experience any vibrations. It was until last week that i finally had the time to replaced the rear engine mount and that's when the vibration started. It was mention on some post that the vibrations might eventually stop after driving the car for a while, since it might be that the engine mounts are new and stiff, but I don't know if that is true or not. On one hand the vibration in idle is kind of annoying for this type of car, but on the other hand, it almost give you that feeling of a muscle car with a big Hemi engine under the hood.
RG08RL is online now
Old 04-12-2019, 06:33 PM
Registered Member
deepa1600's Avatar
Today i changed the front mount. It was PITA, i did it without removing fans as my rfc unit's screws were rusted.
Old 04-16-2019, 07:47 PM
Registered Member
update: Took the car to the dealer and they found that the passenger mount was broken, yes the new one I installed. I got a hold of mount_expert on eBay and they promptly refunded my money with just a picture of the broken mount (great service) I did opt to buy the OEM mount. I installed it myself and still am having the vibrations at a stop light or stop sign or anywhere I'm stopped with the car in gear.
I'm also feeling the vibrations around 60 mph. I decided to do a little test - I put the car in manual and around 60 I stayed in 4th and got zero vibration, put it in 5th and the vibrations came back. Not sure what that means but it's something. I'm going to take the back to the dealer next week to have it looked at again, I'm at a total loss. They double checked all my work and all of it was perfect, now I wait, which I'm not good at doing.
I'll update again next week.
H8PVMT is offline
The following users liked this post: H8PVMT
RG08RL (Today)
03_BigJ_TypeS
21
08-01-2014 12:29 AM
NighthawkBlue
Second Generation CL Discussion (2000-2003)
32
10-24-2012 02:39 AM
luxerymobile
Second Generation TL (1999-2003)
03-29-2011 12:48 PM
HQTL6SPD
08-08-2010 06:52 PM
Quick Reply: Transmission mounts - need some help
