Transmission fluid filter
Has anyone ever replaced the transmission fluid filter on a '05 RL? Reason I ask is because I did see a filter on Acura parts website and wondered if anyone has done this before. From the looks of it, it is located on the timing belt side which can't be right. It is #3 in the photo. Figure might as well change it especially if I am doing a 3X drain and refill over a 3 week span. Of course I will change #23 ring that goes on the end of the filter.
http://www.acurapartswarehouse.com/d...ipe-226931.png
It is considered a non-maintenance part. I have not seen anyone here change it, but it has been discussed.
From the service manual,
Originally Posted by Auto Transmission, pg 426
ATF FILTER REMOVAL/INSPECTION/INSTALLATION
1. Remove the three 6.0 mm bolts securing the ATF filter cover (A) and ATF pipe (B).
Fig. 444: Identifying ATF Filter Cover And ATF Pipe With Torque Specifications
Courtesy of AMERICAN HONDA MOTOR CO., INC.
2. Remove the ATF pipe from the ATF filter cover, and remove the ATF filter (C) from the cover.
3. Clean the ATF filter, then check that it is in good condition and not clogged. Replace the ATF filter if it is
clogged or damaged.
4. Install the ATF filter with the new O-ring (D) in the filter cover, and install the ATF pipe in the cover,
then install them in the transmission housing.
5. Secure the ATF filter cover with the two bolts (E), then secure the ATF pipe with the bolt (F).
clogged or damaged.
HEAVY_RL (11-25-2012)
That doesn't sound like a bad idea at 200k+. Are you doing it yourself? If so, could you take some pictures for us? This would be a new DIY.
SidhuSaaB
05-30-2020 12:40 AM
