TL Type S converter for RL
According to a post in this forum titled "P0420?? Need help." by sqranks in 2011 the TL type S converter is the exact same part.
If you replaced your RL converter (18290-RJA-A00) with the TL type S converter(18290-RYE-A00), I'd appreciate hearing whether the P0420 code came back? Thanks for your help. I plan to buy one or the other, and since the TL one is a couple hundred dollars cheaper, it pays to check it out. |
You should have no issue. The V6 Accord is the same figment too, but it doesn't flow as well.
Originally Posted by Getterdun
(Post 15601533)
If you replaced your RL converter (18290-RJA-A00) with the TL type S converter(18290-RYE-A00), I'd appreciate hearing whether the P0420 code came back? Thanks for your help. I plan to buy one or the other, and since the TL one is a couple hundred dollars cheaper, it pays to check it out. +1 Thread Necromacy |
