Three transmission pressure switches. Which to replace?
https://cimg2.ibsrv.net/gimg/acurazi...bc9f1c40f4.jpg
According to this, there are three switches. Two are numbered 11 and are 28600-RKE-004 or 28600-RAY-013 or 28600-RAY-003 and one is numbered 12 and is 28610-RKE-004 or 28610-RAY-013. If one were to replace these for preventative maintenance, should all three be replaced? If not, which ones should be replaced. And does anyone know exactly what each of these regulates? I read somewhere that #11 regulates 4th gear and #12 regulates 3rd gear but that seems too simple and doesn't explain what the second #11 regulates. I would guess these serve dual duty and also regulate line pressure for other gears. And, the big question for me is, do any of them impact the torque converter lock up? |
After glancing at the TC diagram, I am guessing that the #11 switch on the top is regulating the pressure for TC lockup. It looks like the TC is the part bolted to the back of the first diagram.
https://cimg2.ibsrv.net/gimg/acurazi...dedd33d3f1.jpg |
The part numbers I bought were 28600-RKE-004 x 2 and 28610-RKE-004
Originally Posted by projektvertx
(Post 16128279)
I never ended up changing my pressure switches but that would be what you would end up changing.
2x part labeled 11 and 1 label 13. I replaced all 3 after doing 6x3 and the shift is butter smooth now.
What is part #13? And 6x3 seems a bit excessive.
I believe those correspond to the part #s I provided.
Originally Posted by Huskymaniac
(Post 16130127)
For the folks who want to tackle this job I've taken photos to help you identify the location of these switches. In total there are three switches. 2 28600-rke-004 for the 2nd and 4th pressure switches and 1 28610-rke-004 for tue 3rd gear pressure switch. The hardest one to do is the rear. I bought from a brand named Sins on Amazon based on positive reviews. Saved a few bucks over oem.
https://cimg0.ibsrv.net/gimg/acurazi...cf0e328034.jpg 4th pressure switch https://cimg0.ibsrv.net/gimg/acurazi...bf6dc6df36.jpg 4th pressure switch. must remove air intake box https://cimg4.ibsrv.net/gimg/acurazi...925659f9ee.jpg 3rd gear pressure switch. access through the driver side wheel well. remove wheel and plastic panel. https://cimg1.ibsrv.net/gimg/acurazi...f0032b381d.jpg 2nd gear pressure switch. hardest to reach out of the three. took me 2 hours because I used too big of a ratchet..then finally figured out to use a smaller ratchet and was able to make it work. this is behind strut bar. hard to find. https://cimg9.ibsrv.net/gimg/acurazi...21ffbea9c5.jpg https://cimg5.ibsrv.net/gimg/acurazi...c676672a44.jpg 2nd gear https://cimg6.ibsrv.net/gimg/acurazi...262960a40f.jpg 3rd gear https://cimg8.ibsrv.net/gimg/acurazi...f2bfb14f35.jpg I used a deep socket 22mm and a 3/8 drive with a 1/2 adapter |
the rear one is fun isn't it? lol.
My TL gave me a lot of clue where the switches reside as the TL use the borrow design from the RL. |
(Post 16447488)
