Things to change at 95k
Aloha!
I will be installing my aspec springs soon, and since I will have it all taken apart, is there anything I should be replacing while I'm in there?
Car got 94k miles. Haven't changed much she has been a dream since a bought her. Would it be safe to assume the struts would be 'bad' with this many miles?
I would replace your struts and strut mounts, especially considering you have to take them apart for the front. I'd jack the car up now and evaluate the integrity of upper and lower control arms, in addition to any other suspension components.
Ok got it. I was leaning towards new struts too so you just confirmed my decision. What would I look for when inspecting the control arms? Ideally I'd like to get it all out of the way at once.
Oem strut part number
Also, does anyone have the strut part number without springs for non aspec? I can find out using those insane looking part map lol but if someone has the info handy already that would be greatly appreciated
With regard to control arms, you'd need to inspect the bushings and ball joints for any tears or rips. In addition, you should use a pry bar and check for play. There shouldn't be much movement if any at all.
Below is the part # you need. My invoice from last year. You should also look to flush the power steering fluid and inspect the engine mounts.
nickelrw87 (02-17-2018)
damn i love you guys almost as much as i love my RL lol Thanks so much for that screenshot! I think ill try and have a mechanic friend come by while i do this to supervise haha
nickelrw87 (05-05-2018)
The control arms themselves should be good unless they have cracks and shit right? Otherwise the bushings I can see being changed.
The control arms are solid. Problem is that the ball joints/control arms (upper & lower) are one piece, so the whole arm gets replaced.
Rockauto is your best bet for budget friendly parts.
Also, out of all the brands on rock auto for these arms (Beck arnley, mevotech, acdelco, Moog etc) which is best? I've been trying to keep it oem for the most part because of no particular reason.
I have Beck/Arnley - very good performing parts.
Additionally, I would recommend checking Engine mounts: there is a chance that you need to replace 2 out of 3 at that age/mileage. I replaced all three since they were working on it anyway
nickelrw87 (02-22-2018)
well this project went from 650 bucks to over 1300 just in parts real fast haha I may have to break this down into smaller chunks for a smaller financial burden. I haven’t done much at all for the 4 years I own her and I’m finally in a position to afford these things, she treated me so well the car deserves all these new parts
I assume it wouldnt matter if you mix and match brands? For example:on Rock Auto Beck Arnley have all but one arm - the front right upper. Mavotech and Moog makes that arm i guess lol
I know almost every RL that has been somewhat cared for has needed struts as well as engine mounts around the 95-100k mark. I'm assuming you know the timing belt as well as fluid checks. Another big one is the power steering pump, but as you know it makes a lot of whining when it goes out. I know the drive belt tensioner is a common replacement as well as the coolant hose pkg.
