Subtle whistle
Driving downtown with windows down, passenger side, there's a little whistle. It's not a whine, or speed related. I drove near a building wall, and from the passenger side you can hear it.
My first guess was something around the tirres, behind the tires... Anyone had something like this? |
This whistle is even if the car is in neutral running down a slope. However, in reverse gear it's not there, once back going forward, its heard. It's on the right side.
It's like some kind of a bearing, or a rubber somewhere became thin.... I just do not know what possibilities it can be. Any ideas? |
It could be the loose windshield moulding near A pillar on right side.
Maybe, if your lucky, a turbo is starting to grow! :D
Originally Posted by deepa1600
(Post 16451578)
(Post 16451589)
I don’t want to freak you out, but the drive shaft howl people talk about can start off like a whistle before it gets worse. Now if it was the drive shaft bearing normally it occurs at certain speeds only until it gets very bad and u can hear it with the windows up and from either side of the cockpit. This is probably NOT your issue, but at least u could rule it out. Also, check out your splash guards around the front passenger wheel well. Maybe a clip or two broke and it’s hanging making a whistle. Idk otherwise.
Originally Posted by grappler171
(Post 16461280)
