Rust just coming through on my 05 RL
Please help me. I've been advised that this rust above the rear wheel well can be cut out and refinished but it's temporary. The other option is to replace the entire rear quarter panel at about $2500. I'd just like to thwart the growth of the rust. Does anyone have a trick that can keep the rust from running rampant? Superglue to close the breakthrough??? Any rust deterants that could hold the growth off for a while? I know someone has some magic solution to keep the rust from growing like a weed. Will you please share your experience with your trials with me? Please let me know if you have questions. This car has 208,000 miles on it but looks like a 2 year old car. No door dings, no seat wear, etc. We have other daily drivers but I just can't part with this for some reasen and/or what someone would give me. I've done all the maintenance at Acura as called for; someone always asks me if they can buy it but who really wants to buy a car with 208K unless the took care of it?
I'm looking for any rust deterent option that might be possible. Again, I'm only hoping to hold it at bay! I understand that it will eventionally take over.
Thank you forum,
GRL
Thank you forum,
GRL
Thank you forum,
GRL
Thank you forum,
GRL
My recommendation would be - based on how big the area is, consider fixing maybe but replacing the whole piece - not worth in my opinion for such old car...
FWIW: Had a similar rust issue at the center top area of the right rear quarter wheel "lip" on my 03 TLS. Removed the r/r wheel, wire brushed and sanded the entire inside of the wheel lip area, coated the area with POR 15, and topped it with spray on undercoating. That was over four years, and 50K miles ago, and, fingers crossed, no further spread of rust, at this time. Current miles, 244K
Thanks!
I didn't take any pics., prior to or after, sorry. What I had, was small rust bubbles forming on the outside of the flat portion of the passenger side rear wheel lip. The rust was very viable on the inside of the wheel lip, the portion which runs parallel with the tire. A 4-5 inch section of the wheel lip, was actually rusted off. After I treated the underside of the lip, I installed a 7/8" black rubber wheel lip molding on the outside of the wheel lip, to cover the small rust bubbles. Prior to installing the molding, I peeled the rust bubbles off, exposing the underlying rust, dried them out, with a heat gun, treated them with POR15, and than installed the molding.
Neil2theTL
09-08-2012 10:46 AM
Jottle
07-22-2012 02:45 PM
