Rl wheels and tire size?
Old 02-27-2014, 10:33 PM
sergiu's Avatar
Can I fit a 20x10 wheels on the rl with out rubbing and since it's awd do the tires all have to be same size or can I put wider tires in the rear
Old 02-27-2014, 10:38 PM
BDoggPrelude's Avatar
20x8.5 or 20x9 would be a safer bet. I can tell you right now that my summer wheels are 20x9 +35 offset with a 255/35R20 and they rub a tiny bit in the rear over big dips/bumps.
As for AWD and different sizes...that's up to you. If you hate yourself and prefer a stupid look over function, performance and practicality, you can put wider tires in the rear. The RL is not a 400hp RWD sports sedan. It does not need wider rear tires.
Old 02-27-2014, 10:51 PM
sergiu's Avatar
The wheels I wana put are 20x10 with a offset of 42 if that makes a diff
Old 02-28-2014, 12:08 AM
Like I said, my 20x9 +35 wheels rub on the rear fenders over big dips and bumps. The wheels you are proposing stick out 6mm more than mine. You do the math.
Old 02-28-2014, 04:40 AM
MSW 6SP's Avatar
20x9 with +42 offset should not rub at all. Any lower offset and it's going to rub the fenders if they are not rolled. I would not put 10 inch wide tires in the front. If you could manage to pull it off, the negative camber will chew through the tires so fast.
Old 02-28-2014, 08:37 AM
oo7spy's Avatar
Received 7,244 Likes on 4,855 Posts
Old 02-28-2014, 03:58 PM
ChocBoyWonder's Avatar
Originally Posted by oo7spy
I think I can +1 this post lol
Beweary of what you ask...esp without searching. I guess I haven't beaten this topic totally dead yet LOL
Old 02-28-2014, 04:16 PM
HEAVY_RL's Avatar
Received 1,037 Likes on 843 Posts
Old 02-28-2014, 05:20 PM
sergiu's Avatar
Just wanted to make sure before I bought the rims thanks guys
booma1218
05-03-2016 07:39 AM
GhostTL09
09-19-2015 01:57 PM
nuldabz
09-03-2015 05:49 PM
Quick Reply: Rl wheels and tire size?
