Notices
Rl upgrades?
Old 01-23-2017, 10:32 PM
Registered Member
Rl upgrades?
i have a 2006 acura rl sh-awd A-Spec edition. I have a short ram intake and deleted all 3 cats already with flowmaster 40s on my dual exhaust... i also just ordered an AFE throttle body spacer and it's on the way. What are some other upgrades i could do? I've seen some talk about the j37 intake manifold?
I am new to the forum. Any help would be great. Thanks.
Michael
Mpetty85 is offline
Old 01-24-2017, 08:37 AM
Registered Member
thisaznboi88's Avatar
nitrous , light weight pulley, P2R intake manifold spacer,
thisaznboi88 is offline
justnspace (01-24-2017)
Old 01-24-2017, 08:57 AM
Received 14,119 Likes on 10,496 Posts
throttle body spacers dont do jack shit!!!
any air tuning is done in the intake manifold and NOT before it.
so, increasing volume by a intake manifold spacer WILL give you gains...throttle body spacers are junk.
might want to get rid of the short ram intake, as it's just breathing the hot air from the engine.
and the J-series engine that has been in production since 1996 is known for heat soak.
justnspace is offline
projektvertx (01-24-2017)
Old 01-24-2017, 08:58 AM
the best free mod is to take that piggy to the gym and lean her out.
she'll accelerate better, brake better, corner better just by taking a few hundred pounds off the car
Old 01-24-2017, 09:10 AM
Registered Member
I have a carbon fiber heat shield around the air filter to help any heat soak that may come through filter. I have taken the spare tire and jack out to help reduce weight. Aso i am looking into fabricating a functional hood scoop to ram air in and possibly a cowl at the back of the hood to help hot air escape. I also want to get the intake manifold spacer and thermal gaskets.
Thanks guys
Mpetty85 is offline
Old 01-24-2017, 09:13 AM
nice plans for cutting up the hood!!
my buddy did M3 hood vents to let out hot air. the m3 hood vents are positioned over the fuse box, so I wouldnt do that...but Mercedes Benz models have LARGE cowls that go across the rear of the hood. thats the route I want to take
another buddy played with the idea of the Jaguar XF "supercharged" hood vents but they ALSO tend to look good only over the fuse box
Registered Member
Do you have a link to the light weight pulley?
Mpetty85 is offline
Old 01-24-2017, 09:16 AM
Shop Online | Excelerate Performance
Old 01-25-2017, 09:39 PM
oo7spy's Avatar
Received 4,550 Likes on 3,248 Posts
If you look at the RL intake, it eventually ends up at the front edge of the hood just behind the driver's headlight assembly. Unfortunately, it goes underneath the battery to get there. I had always dreamed of finding a way to get it around the top of the battery in a straigh line so that it would create a ram effect.
oo7spy is offline
Old 01-26-2017, 10:24 PM
Registered Member
Weight reduction?
i have removed the spare tire and jack to reduce weight. As this is my daily driver, what else could i remove
without affecting functionality? I have a 2 year old son so I can't remove the backseat due to his car seat.
Seriously thinking about a light weight crank pulley. What j-pipe would be good?
thanks
Mpetty85 is offline
Old 01-27-2017, 05:41 AM
Registered Member
So I presume your maintenance is up to date and timing belt work done.
I swapped the crank pulley when I had TB done and tech was amazed at the diff in pull. I didnt see it but he did. Whats your ultimate goal? Do you want show vs go or show and go?
You could reduce weight by swapping out those wheels with lighter weight ones? You can pull all trunk trim out (which is minimal change) but your not gonna get much more reduction than all thats mentioned in your thread.
08KBP_VA is offline
Old 01-27-2017, 06:28 AM
There maybe a few steel/rubber anchors hidden in places to damper noise and vibration.
Changing out OEM parts for lighter after market parts, like exhaust and wheels. 2 piece rotors which decreases rotating mass
Move to a light weight battery with the same or more cranking amps
RV6 Performance Fabrication, Engineering, R&D, Manufacturing for jpipe
Old 01-27-2017, 08:26 AM
Registered Member
just do nitrous. easy bang for the buck
justnspace (01-27-2017)
Old 01-27-2017, 01:04 PM
oo7spy's Avatar
Remove all your speakers. Then the A/C. Then the windows, trunk lid, hood, etc.
But seriously, unsprung weight has the biggest effect on performance. Get your tire and wheel weight down.
oo7spy is offline
Old 01-29-2017, 09:04 PM
Registered Member
Thanks guys. I have already replaced stock mufflers with flownaster 40s and i have removed all 3 cats and replaced with straight pipe. (I live in South Carolina, no smog or emissions testing) i have replaced brake rotors with cross drilled and slotted performance rotors. I am doing my timing belt and water pump this week( using light weight aluminum water pump) also going to switch out the crank pulley with a light weight RALCO RZ pulley and going to replace the tension pulley with a light weight UNORTHODOX tension pulley in the process. And while I'm in there going to add the p2r intake manifold spacer with thermal gaskets. And looking at some light weight aluminum wheels. I have the ASPEC kit on my RL and it come with heavy chrome wheels. So should be some weight reducing going in there along with the pulleys. Thanks for all the input.
Michael
Even my 2 year old son wants to remove the heavy aspec wheels lol
Mpetty85 is offline
Old 01-29-2017, 09:20 PM
Registered Member
good start Maybe a 3.7L imtake manifold with matching TB? Custom 4 in CAI instead of that short ram
The following 2 users liked this post by thisaznboi88:
projektvertx (01-29-2017), teh CL (02-02-2017)
Old 01-29-2017, 09:47 PM
projektvertx's Avatar
Wow, an RRP A-Spec with the adaptive cruise!! Talk about a combo you don't see much!!!!!
projektvertx is offline
oo7spy (01-29-2017)
Old 01-29-2017, 09:54 PM
Registered Member
yeah this car has all the features possible for the 06. Tech package with navigation and adaptive cruise, collision mitigation and the a-spec kit and wheels. This is the only RL I have seen in my small city of Gaffney South Carolina (population 12-13,000) lol
i get many compliments on it. It's in need of a paint job to touch up the little chips over the years. Going to keep the redondo red pearl though
Mpetty85 is offline
Old 01-29-2017, 10:30 PM
oo7spy's Avatar
That is a rare combo. I've seen one RRP on the street and it was rocking only a rear ASpec underbody spoiler of all things.
Nice car!
oo7spy is offline
Old 02-02-2017, 02:07 PM
Registered Member
fuzzysig's Avatar
justinspace
you are slightly wrong about htat
the intake tube is an extension of manifold and does have an effect on
but you are right in that spacers wont do jack on this intake manifold design
it sits on top of the motor and heatsoaks from being on top of the motor regardless of what gasket you use
4 banger intake manifold is on the side and having a gasket helps just slightly mostly due to IAT sensor being less heatsoaked and dumping more fuel into it...
porting the manifold and head would actually work great but will need tuning
heatsoak from the engine bay is negligible in the real world its only a few degree difference
plus the intake filter on RL is inside the fender. nowhere near the engine or any heat source
ram air intake would definitely help on the freeway
and I belive RL has a dual chamber muffler as well so it is pretty good for a stock exhaust system
fuzzysig is offline
Old 02-02-2017, 02:16 PM
meh. there are dyno's showing the intake manifold spacer gaining 3-5hp
also, the MDX comes stock with an intake manifold spacer....
why would honda/acura provide the MDX with an intake manifold spacer!?!? because it improves mid-range torque.
the spacer acts like an extension of the intake manifold...
NOT the intake tubing..
Old 02-02-2017, 05:31 PM
Registered Member
It increase the runner length at the cost of top end, but since the RL doesn't high rev who cares. The RL need the TQ.
justnspace (02-03-2017)
Old 02-03-2017, 06:56 AM
^agreed
Old 02-03-2017, 12:38 PM
Registered Member
fuzzysig's Avatar
theres also dynos showing increase in intake length has same effect to a certain point
the intake tube TB and intake manifold all the way down to the valve opening is one system
I personally tested 5 different intakes and an adjustable length intake tube to find the sweet spot for my motor.
mid range at the expense of top end depending on where you want the power curve to peak.
fuzzysig is offline
Old 02-03-2017, 12:49 PM
^but arent you the one ALWAYS asking for information?? lmao.
thisaznboi is turbo'd
and Ive been at it for 7 years
I'm pretty much bolted on and know the engine like the back of my hand.
I've changed the heads to my engine myself, to 3.7l MDX heads.
Old 02-03-2017, 12:51 PM
also, 4 inch intakes is where it's at.
there's power to be had with 4 inch diameter intakes
Old 02-03-2017, 05:04 PM
Registered Member
fuzzysig's Avatar
I am asking things I don't know. whats your point?
fuzzysig is offline
Old 02-03-2017, 05:12 PM
Registered Member
you should come hangout with the 3rd gen TL people :p
Old 02-04-2017, 09:05 AM
point is, you have LOTS to learn my friend!!!!!!!!!!!!!!!!!
it wasnt a dig at you.
simply, we have DONE everything imaginable to the J32/J35/J37.
WE know what makes power! so you dont have to experiment
Come hangout in the 3G TL section!!!! you will learn A LOT!!!!!!!
Old 02-04-2017, 09:08 AM
this aznboi is hitting 350-400HP!!!!!!!!!!!!
that's SUCH AN AWESOME accomplishment!!! with such a hard motor to make gains....
Learn and COPY from us!!!!
Old 02-04-2017, 09:17 AM
Registered Member
AccordFlex is making ~450whp/~400wtq on the same dyno with a j35a8 stock block.
https://acurazine.com/forums/3g-tl-p...-887133/page5/
I am only on a 3.0L so nothing special
