RL gone crazy.
RL gone crazy.
So about a month and a half ago i went to reverse out of my driveway and when i put the car in to gear it just went ape shit, the Emissions light came on, check transmission on the mid, AFS came on, blah. I turned my car off and back on then no lights except check emmisions came back. I disconnected the battery to see if i confused a sensor or something, and vwala! all was good, or so i thought. The code did store in the computer, But all was good untill today. I started the car, then boom. AFS,Emmisions,Transmission, No Keyless entry. I just want to now if anyone else had this problem happen to them. im not really concerned since the car is running well i just wanted to get some insight on what the problem might be before i go to the dealer and get anal probed.
go to autozone and get the battery checked out. Many issues like this are caused by a dying battery, and with the electronics laden RL, it wouldn't surprise me that if it was just your battery not giving the correct voltage at startup and spiking a module or two with electric!
Yeah well i took it to autozone to have the codes checked out, but there are no codes. he hooked it up and said man you have nothing showing up your good, so i think it is the battery. Thanks guys
This has happened to me. It registered a code "p1717. I noticed that the car was shifting and driving a slightly differently.I came to realize it was my gas cap not being screwed on tightly.Once I squared that away and restarted the car it all went away.This may be what you are experiencing. You can start with this and see if it works.
mike from annapolis
05-07-2017 08:21 PM
Medinak12
09-23-2015 07:11 PM
