replace hid light on driverside....
Old 09-22-2012, 03:52 PM
christopher1's Avatar
Do I have to remove front bumper or can I just take battery out and get my hand in to replace bulb. I do not want to give dealer 300.00 to replace a $30.00 bulb in my 05 rl. Has anyone done it and how hard is it? This is the hid low beam bulb....
Old 09-22-2012, 05:21 PM
M T L T L's Avatar
Remove the wheel, then remove the linning n plastic covers. U will have better access from the wheel wel than from the top.
HEAVY_RL (09-22-2012)
Old 09-22-2012, 08:36 PM
getakey's Avatar
Hmm - have not heard of replacing through the wheel well. Is it a straight shot that way?
You can do it from the top by removing the battery. Its a mostly blind operation and tight squeeze. Stuff rags under and behind light assembly in case you drop bulb.
Search and you can find lots of threads on this
Old 09-22-2012, 08:39 PM
M T L T L's Avatar
Did the passenger side through the wheel well, took 5 mins. U have direct line of sight. I assume should be the same for driver side.
Old 09-23-2012, 12:00 AM
Carbon Legend's Avatar
id pull the battery. getting around the OEM intake can be tricky replacing the bulb
Old 09-23-2012, 09:20 AM
oo7spy's Avatar
Received 7,244 Likes on 4,855 Posts
5 min? C'mon. You couldn't get your jack, lift the car, loosen lugs and remove the wheel in 5 min.
You HAVE to do this procedure on the 350Z. It is a pain in the ass, but mostly because of how tight the back cover of the light assembly was on.
Old 09-23-2012, 10:13 AM
M T L T L's Avatar
5 mins after having the wheel removed and the pins that hold the plastic covers.
oo7spy (09-23-2012)
Old 09-23-2012, 10:47 AM
white05rl's Avatar
You can also do it (from the top) without disconnecting the battery. I did, but it took some time and some patience.
Old 09-23-2012, 10:49 AM
white05rl's Avatar
Also, if you have to replace one bulb, you might as well do both. Start with the passenger side, as it's the easiest and will give you a good idea of what to expect on the driver's side (since much of it will be by "feel" if you decide to leave the battery connected).
Old 09-23-2012, 01:15 PM
oo7spy's Avatar
^ Yes, you can remove the battery tie down and slide it about 4" towards the engine without disconnecting any wires.
mada51589
05-03-2022 08:54 PM
cycdaniel
12-17-2019 10:58 AM
pozebly
09-23-2015 07:30 AM
pesobreeze
1G RL (1996-2004)
09-03-2015 12:26 PM
voigt
09-02-2015 10:44 PM
Quick Reply: replace hid light on driverside....
