Recommended Bluetooth Option for iPhone - AcuraZine - Acura Enthusiast Community
Notices
Old 03-12-2018, 09:39 AM
CJP
Registered Member
Greetings! Just purchased a 2005 RL and need some help with figuring out the best option/device for being able to play my iphone through the sound system. I've seen these two on a couple of YouTube video's:
  1. USA Spec PA15-ACUxl Y-Harness
  2. USA Spec BT45-ACI
From what I see, both of these hook into XM/Satellite unit in the trunk. Crutchfield told me they have a bluetooth unit that goes behind the stereo. It's something like a $185.
Any other options? Any better options?
Thanks,
Chris
CJP is offline
Old 03-12-2018, 01:03 PM
Registered Member
truonghthe's Avatar
Thanks,
Chris
Fixed.
  1. USA Spec BT-45Hond
  2. USA Spec BT45-ACU
Buy the USA spec and call it a day, if you get the type that plug on the back of the radio you will loose XM radio completely.
truonghthe is offline
The Following User Says Thank You to truonghthe For This Useful Post:
projektvertx (03-13-2018)
Old 03-12-2018, 02:20 PM
CJP
Registered Member
Thank you.
So the USA Spec BT45-ACU is connected to the XM receiver in the trunks left hand side?
CJP is offline
Old 03-12-2018, 05:51 PM
Registered Member
truonghthe's Avatar
Originally Posted by cjp View Post
thank you.
So the usa spec bt45-acu is connected to the xm receiver in the trunks left hand side?
yes.
Old 03-12-2018, 11:05 PM
Registered Member
I bought a 2005 RL in December and installed a USA Spec BT-45Hon. It was very simple to install. Yes goes in the trunks left side. YouTube game me an idea of how it all hooks up. You will not loose XM. You have XM1 and XM2, xm1 will be Bluetooth and xm on xm2.
galavizjg is offline
Old 03-12-2018, 11:08 PM
CJP
Registered Member
Thank you.
Any ideas on adding a power supply somewhere? Trunk is fine with me.
CJP is offline
Old 03-13-2018, 08:44 AM
Registered Member
truonghthe's Avatar
Thank you.
What do you mean by power supply?
Old 03-13-2018, 11:36 AM
CJP
Registered Member
Like a cigarette lighter outlet, 12v I think. There's one on the console, one in the console, would like to have one in the trunk...unless there's one I don't know it.
CJP is offline
Old 03-13-2018, 05:07 PM
projektvertx's Avatar
Thank you.
It's plug and play, draws it's power from the XM harness, no power source necessary.
projektvertx is offline
Old 03-13-2018, 05:28 PM
Registered Member
truonghthe's Avatar
the module came with a USB port (charging ONLY) so you can plug whatever USB cable you choose to.
ajelder01
02-16-2013 06:58 PM
randini
06-19-2009 02:11 PM
cuhrupt
11-01-2007 01:33 AM
01BLKonBLK
03-06-2007 01:17 AM
mobilezen
147
10-21-2005 12:32 AM
Quick Reply: Recommended Bluetooth Option for iPhone
