Pillar water leak
Fk no!TheyldstroyEvrthing
Pillar water leak
Anyone ever figure out where on earth is this stupid water leak is from??
My passenger pillar is soaked. I taped the windshield trim with electrician tape, it still leaks.,
If from sunroof, well it should drain down....
WTF?
WTF?
You can quickly tell if it’s the drain hole by pouring water into it. With mine, the back end of the drain hole had become disconnected from the tubing that runs down the pillar caused by a ham fisted windscreen fitter. Took ages to dry the car out afterwards, I was misted up for weeks. It was fixed by the dealer who I believe accessed the connection from inside the car pulling back the roof lining.
Good luck.
Good luck.
I also had a leak in the same place. For my car the seal over where the roof sections had been welded together cracked and I fixed it by putting silicone caulk over the area. I had to remove the trim piece that covers the weld. This is done by pushing the piece forward and lift it up. It is not difficult.
cnestor (02-04-2024)
Good luck.
Good luck.
That was my mechanic's idea. He wants to remove the pillar trim next week as he thinks the tube inside may be dislodged. He may find out the weld is a manufacturing default and epoxi or silicone it.
Will try and take pictures and/or update.
Cause this be caused by the windshield change? Now they wanna change it again. I'm reluctant, as i don't think its the reason.
Could you please specify where is the location you speak of?
The other ideas I tried.
I took out those plastic rails that run across the roof from front to back, I have zero rust there.. Actually there's some metal dust in there... is that since production or accumulating from some grinding somewhere?
I just have grey/silver metal powder.. and the roof under than trim is totally rust free. Yet, pillar leaks from the exact same location as yours.
The body shop couldn't have guessed until i removed that molding just to show, and he saw it not me. He thinks its a manufacturing defect. It's not sealed properly to avoid getting rusted.... Honda actually really sucks that way.
Did you have to have bought that rust warranty or is it on all cars? I mean its their freaking fault...
It seems to be a defect in the manufacturing yes. Honda said they have never seen this and said no in the begginning. But after a long time with much work they said ok.
All Hondas in Europe has a 12 year old warranty since 2007. But only if the car has been serviced at the dealer every year. Luckily for me mine is thanks to the first rich owner ha ha.
My A-pillar is leaking for the 3rd time (2005 RL) - first removed the trim piece above the door on the roof drip rail, then pulled back on the black piece of trim that runs down the side of the windshield - found the pinch weld for the roof was rusted, put a dab of caulk on it and that fixed it.
Last year A-pillar started dripping from a different spot, repeated steps above bu this time it looked like the rubber gasket was eroding - there was definitely some loose rubber pieces in that joint - it's almost more like a rubber/foam gasket than pure rubber. Filled in the gap with caulk, car was fine again.
Today it's raining, I go out for breakfast, A-pillar dripping from original location again - CRAP! I'll try to use a better sealant this time instead of bathroom caulk, but I think that gasket may be dry rotted and needs to be replaced. Looked at a site that showed steps needed to replace the windshield and it's a multi-hour job with the chance to break all kinds of trim and cowl pieces - here's a slide show of everything that needs removed:
https://www.ableautoglass.com/SSW-A-...eplacement.htm
Looked at some online glass replacement estimates and no way they're as cheap as they claim (don't have any Acuras on their example cost list) - cost including windshield is $300-$600 - from that slide show above, looks like it might cost $300 in labor just to remove and replace all the trim pieces, the cowl, and engine covers. Wondering whether I should by replacement trim clips in advance, as at least one is sure to break.
Looked at some online glass replacement estimates and no way they're as cheap as they claim (don't have any Acuras on their example cost list) - cost including windshield is $300-$600 - from that slide show above, looks like it might cost $300 in labor just to remove and replace all the trim pieces, the windshield wipers, the cowl, and engine covers. Wondering whether I should by replacement trim clips in advance, as at least one is sure to break.
A pillar removal
Any advice on how to remove would be appreciated..
recently had a huge downpour and got a small leak on my driver side on the upper side of the pillar. I have plans on getting a new windshield but wouldn't mind taking a closer look before I do. I'm thinking a rust issue as I do have small bubbles starting on the roof right after the trim . Thanks for the help in advance.
My fix for A pillar 08 RL
I just fixed my 08 RL leak by a professional. Approximately $325 to take the windshield out and reseal it and they fixed a 6” rust spot. After searching the forum I removed the trim rail on the roof and cleared the drain holes with line trimming string and it was still leaking. I figured it was better to pay someone to fix the issue and it hasn’t leaked since.
