Pillar water leak
Anyone ever figure out where on earth is this stupid water leak is from??
My passenger pillar is soaked. I taped the windshield trim with electrician tape, it still leaks., If from sunroof, well it should drain down.... WTF? |
I had the same issue, try putting sealant on weather stripping where windshield meets roof.
Try Search? I believe there are posts that indicate those drains can become clogged, and need to be cleaned.
I keep my sunroof closed for that reason. |
You can quickly tell if it’s the drain hole by pouring water into it. With mine, the back end of the drain hole had become disconnected from the tubing that runs down the pillar caused by a ham fisted windscreen fitter. Took ages to dry the car out afterwards, I was misted up for weeks. It was fixed by the dealer who I believe accessed the connection from inside the car pulling back the roof lining.
Good luck. |
I also had a leak in the same place. For my car the seal over where the roof sections had been welded together cracked and I fixed it by putting silicone caulk over the area. I had to remove the trim piece that covers the weld. This is done by pushing the piece forward and lift it up. It is not difficult.
Originally Posted by deepa1600
(Post 16414213)
Originally Posted by DanL07RL
(Post 16414275)
Originally Posted by Legendliving
(Post 16414328)
Good luck. |
Originally Posted by dapqam
(Post 16418829)
That was my mechanic's idea. He wants to remove the pillar trim next week as he thinks the tube inside may be dislodged. He may find out the weld is a manufacturing default and epoxi or silicone it. |
Will try and take pictures and/or update.
Cause this be caused by the windshield change? Now they wanna change it again. I'm reluctant, as i don't think its the reason.
(Post 16418829)
The other ideas I tried. |
My car has the same problem, Honda is now replacing the whole roof on warranty Totally rusted from inside. 2008 Legend.
Originally Posted by Lowpass
(Post 16431416)
(Post 16431416)
I took out those plastic rails that run across the roof from front to back, I have zero rust there.. Actually there's some metal dust in there... is that since production or accumulating from some grinding somewhere? I just have grey/silver metal powder.. and the roof under than trim is totally rust free. Yet, pillar leaks from the exact same location as yours. |
I see, well it seems that the rust comes from the inside. So you may have the waterleak nearby and in the future it might pop up in the rails as it did with mine.
Originally Posted by Walfunk
(Post 16431714)
They are replacing it 11 years later under warranty? Good deal! Is it because the windshield had been replaced?
cool...hopefully they take care of you. good luck!
(Post 16431797)
The body shop couldn't have guessed until i removed that molding just to show, and he saw it not me. He thinks its a manufacturing defect. It's not sealed properly to avoid getting rusted.... Honda actually really sucks that way. Did you have to have bought that rust warranty or is it on all cars? I mean its their freaking fault... |
It seems to be a defect in the manufacturing yes. Honda said they have never seen this and said no in the begginning. But after a long time with much work they said ok.
All Hondas in Europe has a 12 year old warranty since 2007. But only if the car has been serviced at the dealer every year. Luckily for me mine is thanks to the first rich owner ha ha. |
My A-pillar is leaking for the 3rd time (2005 RL) - first removed the trim piece above the door on the roof drip rail, then pulled back on the black piece of trim that runs down the side of the windshield - found the pinch weld for the roof was rusted, put a dab of caulk on it and that fixed it.
Last year A-pillar started dripping from a different spot, repeated steps above bu this time it looked like the rubber gasket was eroding - there was definitely some loose rubber pieces in that joint - it's almost more like a rubber/foam gasket than pure rubber. Filled in the gap with caulk, car was fine again. Today it's raining, I go out for breakfast, A-pillar dripping from original location again - CRAP! I'll try to use a better sealant this time instead of bathroom caulk, but I think that gasket may be dry rotted and needs to be replaced. Looked at a site that showed steps needed to replace the windshield and it's a multi-hour job with the chance to break all kinds of trim and cowl pieces - here's a slide show of everything that needs removed: https://www.ableautoglass.com/SSW-A-...eplacement.htm Looked at some online glass replacement estimates and no way they're as cheap as they claim (don't have any Acuras on their example cost list) - cost including windshield is $300-$600 - from that slide show above, looks like it might cost $300 in labor just to remove and replace all the trim pieces, the cowl, and engine covers. Wondering whether I should by replacement trim clips in advance, as at least one is sure to break. |
Last year A-pillar started dripping from a different spot, repeated steps above bu this time it looked like the rubber gasket was eroding - there was definitely some loose rubber pieces in that joint - it's almost more like a rubber/foam gasket than pure rubber. Filled in the gap with caulk, car was fine again. Today it's raining, I go out for breakfast, A-pillar dripping from original location again - CRAP! I'll try to use a better sealant this time instead of bathroom caulk, but I think that gasket may be dry rotted and needs to be replaced. Looked at a site that showed steps needed to replace the windshield and it's a multi-hour job with the chance to break all kinds of trim and cowl pieces - here's a slide show of everything that needs removed: https://www.ableautoglass.com/SSW-A-...eplacement.htm Looked at some online glass replacement estimates and no way they're as cheap as they claim (don't have any Acuras on their example cost list) - cost including windshield is $300-$600 - from that slide show above, looks like it might cost $300 in labor just to remove and replace all the trim pieces, the windshield wipers, the cowl, and engine covers. Wondering whether I should by replacement trim clips in advance, as at least one is sure to break. |
Originally Posted by ex_hacker202
(Post 16829720)
A pillar removal
Any advice on how to remove would be appreciated..
recently had a huge downpour and got a small leak on my driver side on the upper side of the pillar. I have plans on getting a new windshield but wouldn't mind taking a closer look before I do. I'm thinking a rust issue as I do have small bubbles starting on the roof right after the trim . Thanks for the help in advance. |
My fix for A pillar 08 RL
I just fixed my 08 RL leak by a professional. Approximately $325 to take the windshield out and reseal it and they fixed a 6” rust spot. After searching the forum I removed the trim rail on the roof and cleared the drain holes with line trimming string and it was still leaking. I figured it was better to pay someone to fix the issue and it hasn’t leaked since.
