P0401 code and EGR valve
hi all. just wanted to let anyone here experiencing this emissions code that you most likely have carbon build up in your EGR valve. i took mine off today and it was all jammed up with black soot. cleaned it up with some wire brushes and throttle body cleaner and reinstalled it...and no more codes!!!
ichi d (10-18-2012)
Any details on how to remove it? I did this on Legend #1, but the main problem is actually the EGR pipe after the valve being completely clogged. Unfortunately on the 2G Legend, the pipe was practically impossible to remove with the engine in because it was longitudinal. Hopefully it is easier on a transverse engine.
oo7spy (10-18-2012)
yea, remove the engine cover and you can see it. the EGR is kind of right there on the front-right of the engine. it only has an electrical connection and two bolts holding it down. very easy stuff. i have no experience working on cars.
sorry didnt snap any pictures. its dark now. maybe i can shoot some tomorrow, but honestly its super easy. i got this from the 3G TL side after searching...
i believe you can disregard the parts about a new gasket. here's the post i got it from.. https://acurazine.com/forums/showthr...ight=egr+valve
Well, I don't see a lot of value in doing this on a car with 55k miles, but when Legend #1 has 180k, it was a different story.
why not do it now at 55K miles instead of waiting for it to get completely clogged ? it really doesn't take long to do.
when i was at acura, i've seen J-series EGR valves and intake manifold egr pipe completely packed as low as 80K miles
Had mine done at dealer under warranty.
Also came w/ new fuel injectors as this is a known issue with a fix.
Might want to call, it could be one of those free unadvertised "extended" warranty things.
Apparently redesigned injectors.
^ Need more info, please. What do I need to request to get such a service?
Something Acura knows about, see
See post #7, #22, #27 from thread https://acurazine.com/forums/2g-rl-2005-2012-76/sh-awd-pgm-fi-issue-750910/
TSB 08-006
Though now that its "fixed" on ops car and acura can't see the code, might not be able to get dealer good will fix.
TSB 08-006
Not even a month of ownership on my '08 RL and I got this P0401 code. I still have a warranty on it but after reading this thread it seems like something I can do on my own. After doing some searching, I came back with results mainly for the Accord with this code. The majority of DIY's state that I need to remove the intake manifold and along with some carb cleaner and screwdriver, I can clean the hole in question that is clogged up. Just wondering if doing all that is needed to remedy the issue or would doing as the OP described good enough. I'm getting my windows tinted tomorrow so I may just handle this before my appointment.
You can use the Accord V6 or TL-S (J35) cats, but they will reduce performance slightly due to a more constrictive flow.
RV6 makes a high flow cat for the Accord and TL-S that would have to fit since the stock ones are the same.
Resurrecting because I just got this code, along with the Check SH-AWD light. (New owner, second-hand. 107K miles).
I think I've got how to clean the valve itself to remove clogs...does anyone have insight into cleaning the hose out? Pics would be uber-helpful. Thanks guys!
I think this may be the closest you get here. Link: https://acurazine.com/forums/second-.../p2413-927776/
If that doesn't cover it, PM Karol.
P0401
I received this code and it has been intermittent. It'll pop up and then after a few drive cycles it'll go away. Took it to the dealer today to get the air bag recall work done and figured I'd have them look into the intermittent code. So, they came back with $2630 to replace the EGR value and all 6 fuel injectors. I've read the other threads that talk about this being the "recommended" fix but I'm just not buying into replacing all 6 fuel injectors. My car is an '08 with 100900 miles on it.
So, can just the EGR value be done, or more so, just have it cleaned? I saw the other thread where the EGR valve was cleaned but the issue would come back months later.
Is there a way to get the work done cheaper, is there a way to source the parts cheaper? I mean, $2630 is a bit much.
I'm open to ideas. I have a different shop right now that is going to clean the EGR valve and a fuel injector cleaning service (not sure if its anything more than putting something in the gas tank or not)..
Wow hope they provided lube at that price...
The EGR is very accessible and can be DIY. Sometimes, it's as simple as a piece of carbon getting stuck keeping the valve open. I would just take the two 12mm ( or 14mm) bolts off myeslf and inspect and clean with some carb cleaner.
Don't think the fuel injectors need to be replaced if you're ONLY getting that code.
So far, so good, I haven't had it throw the code again. I think the EGR and fuel system cleaning may have done the trick. I read on other forums that the J-Series can build up carbon deposits in the EGR ports within the intake but most of the vehicles had 200K miles before anyone was cleaning out the EGR ports. If the code comes back again in short order I may look into seeing if the ports need to be cleaned.
projektvertx (04-18-2017)
My 2005 RL has started getting this code and of course the Emissions alert and the SHAWD alert comes up too. 145K on my RL so I'm assuming a good EGR cleaning will fix this. Hopefully doesn't take too long. *crosses fingers*
Thinks you're good
projektvertx (05-07-2017)
