Rear passenger Cv half shaft
Old 04-04-2018, 10:27 AM
galavizjg's Avatar
Im getting a clunking sound when I go over bumps. I went other the car and narrowed it down to the passenger rear cv axle shaft. OEM part number is 42310-sja-003. I’m having trouble finding an aftermarket part. The dealer parts dept quoted me $900. I see front drive axles on aftermarket automotive part websites but no rears. Anyone have any experience on this?
Old 04-04-2018, 10:56 AM
galavizjg's Avatar
Couldn’t figure out how to edit.
Its a 2005 RL with 144500
Old 04-04-2018, 01:04 PM
ahm12's Avatar
Acurapartswarehouse.com has it for $618
Old 04-04-2018, 08:01 PM
projektvertx's Avatar
Any way you could have a local rebuilder work on the current axle and rebuild it?
Old 04-05-2018, 12:13 AM
HDNBenjamin's Avatar
Try Raxles?
Old 04-11-2018, 10:40 PM
galavizjg's Avatar
Thank you all for the information. After reading a number of threads on this site I found was what causing my clunking/rattling sound over bumps. It was a loose e brake cable. Since their was little tension on the cable the e brake components would rattle over bumps. Their is an adjustment nut next to the
e-brake pedal a couple of turns and the problem was solved. I saved some serious dollars.
Old 04-11-2018, 11:45 PM
jbird2212's Avatar
Hahaha...Same thing happened to me but thinking it was my sway bar end links though. Couple turns of the adjustment cable and problem fixed
Old 04-12-2018, 06:04 AM
Forums to the rescue!!
chefmatt
03-23-2018 01:09 AM
burnyd
01-03-2017 12:18 AM
mmcv6
10-03-2007 07:00 AM
Quick Reply: Rear passenger Cv half shaft
