low pitch moan at 45mph
Old 12-26-2013, 09:35 AM
RL RT Joe's Avatar
Hello all, I've had this sound coming from what seems to be the front of my RL for about a year now. It's hard to describe the sound, maybe a low pitch rumble or moan that comes on for for about 2 seconds then off for the same time and repeats so long as I'm at a constant 43-46mph. Never going downhill but always on flat road or slight incline.
I thought it was plastic vibrating, like you see on some cars with a separate air dam underneath the front of the car.
Any ideas?
Old 12-26-2013, 11:30 AM
sOLLEx's Avatar
Sounds like your torque converter going in and out of lock-up...manually downshift into 4th gear at the same speed and see if it goes away.
RL RT Joe (12-27-2013)
Old 12-26-2013, 02:38 PM
miner's Avatar
Agree with sOOLEx
Old 12-26-2013, 03:49 PM
HEAVY_RL's Avatar
Received 1,038 Likes on 844 Posts
ditto
Old 12-27-2013, 07:56 AM
RL RT Joe's Avatar
Now that you guys have pointed out "torque converter lockup" as the possible issue, I searched it and found so many posts with the same symptoms. I'll contact acura and see what they come up with.
Thanks everyone!
Old 01-10-2014, 07:49 AM
RL RT Joe's Avatar
it went away in 4th gear.
I took it to my dealership and asked them to look into it.
My 7 year 100K extended warranty ran out Oct 5th 2013. I explained to them that the "noise" started in spring of 2013(while under warranty) and it was my fault that I didn't bring it in last summer. I asked them if they could help with cost since it did develop within the 7 year period. Much to my surprise they covered 100% of the cost as good will gesture.
It helps to have a good working relationship with the dealer and a dealership that puts relationships as a top priority!
Old 01-10-2014, 10:48 AM
oo7spy's Avatar
Received 7,244 Likes on 4,855 Posts
So, what did they fix?
Old 01-10-2014, 11:03 AM
swake457's Avatar
Mine does the same for the about the past year. A low groan at ~45mph and 1,500 - 2000 RPM's, but even at certain highway speeds where that's the RPM range. I've suspected the torque converter also, and it kept happening even after a 3x trans fluid swap. But I'm off warranty even when this started.
Very curious to hear what the dealer says and if they just default to replace the TC.
Old 01-10-2014, 12:26 PM
RL RT Joe's Avatar
The car is still at the dealership. I should get it back on Tues.
I'll post then
Old 01-10-2014, 04:49 PM
HEAVY_RL's Avatar
Old 01-10-2014, 07:49 PM
Mr.RL's Avatar
they probably just put a torque convertor in it which is common across most of the 05-10 acuras i think it was an issue with the build the new ones are from japan and they have different laws about materials and what not
Old 01-15-2014, 07:35 AM
RL RT Joe's Avatar
You're right, I got my RL back yesterday and they did replace the torque converter. (part no. 26000-RJA-316).
As mentioned earlier, this dealership is very good with maintaining a good customer relationship.
HEAVY_RL (01-15-2014)
Old 01-15-2014, 10:29 AM
EL19's Avatar
Does the noise indicate an issue with the TC? Or is this just a "I don't like the sound" issue?
Old 01-15-2014, 01:09 PM
oo7spy's Avatar
Old 01-16-2014, 06:46 AM
RL RT Joe's Avatar
Good question, I'm sure someone with knowledge on this topic could shed some light for us all.
Old 01-16-2014, 07:29 AM
EL19's Avatar
I've had the noise for about 2 years now and all seems to be well (tranny fluid draining cleaning when doing regular drain and fills). Just hoping its more of an annoyance than a more serious issue.
Old 01-24-2014, 09:14 AM
hotdealdave's Avatar
I have it in my 06 that I bought last summer. Out of warranty of course. I think it started at about 75000 miles. I'm due for a differential fluid change but sounds like that won't make it go away.
Old 01-24-2014, 11:26 AM
HEAVY_RL's Avatar
As I've said before, just turn the radio up. haha
Old 01-24-2014, 09:44 PM
7th Gear
eludethis's Avatar
I had that problem before too. Took it in and had the transmission fluid flushed twice to make sure I got as much of the old fluid out as possible. It did the trick for me.
Old 02-28-2014, 03:57 PM
3rd Gear
acurarl2005pr's Avatar
What is teh average price for a 2005 RL Torque Converter?
Old 02-28-2014, 04:17 PM
HEAVY_RL's Avatar
08KBP_VA
10-22-2019 01:55 PM
xsilverhawkx
10-05-2015 11:00 AM
Matthew Purpura
09-25-2015 06:10 PM
Rcelestino93
09-23-2015 10:01 PM
STL TL-S
09-23-2015 08:52 PM
Quick Reply: low pitch moan at 45mph
