LED Running lights
Old 01-02-2012, 09:40 PM
2012 TL SH-AWD
Zelaya's Avatar
LED Running lights
Id like to change my running light for LED. I've been going around the net looking without any success. Has anyone here have any led running light on their RL?
Old 01-02-2012, 10:18 PM
HEAVY_RL's Avatar
Received 1,038 Likes on 844 Posts
https://acurazine.com/forums/2g-rl-2005-2012-76/anyone-done-led-drls-804078/
https://acurazine.com/forums/2g-rl-2005-2012-76/ugly-yellow-daytime-running-lights-836999/
https://acurazine.com/forums/2g-rl-2005-2012-76/little-teaser-video-lighting-related-832731/
https://acurazine.com/forums/2g-rl-2005-2012-76/check-out-these-headlights-led-drls-819983/
Old 01-02-2012, 10:29 PM
oo7spy's Avatar
Received 7,244 Likes on 4,855 Posts
There is also a halo kit out there, but I suggest fog light DRLs.
Old 01-02-2012, 11:02 PM
Sniffles's Avatar
I just did it 2 days ago LOL! IJDM sells the White LED but its not listed under their site for Acura RL. However, I bought it and it works. I am sending them higher resolution pics so they can post it on their site and hopefully they will update it. Also, the LED are only for show so your high beam will not do much but just aim brighter. Also, IJDM has the install instruction and it is exactly the same so there's really no point for me to post it.
DRL BULB- http://store.ijdmtoy.com/9005-LED-Da...d_sku45_r2.htm
Installation- http://store.ijdmtoy.com/Install-LED...ight-a/229.htm
Old 01-03-2012, 08:02 AM
2012 TL SH-AWD
Zelaya's Avatar
Thank you guys for the info. Hey sniffles, compare to the oem bulbs do you see a different on high beam?
Old 01-03-2012, 08:29 AM
Sniffles's Avatar
Zelaya- If you mean visibility while driving, you won't get anything out of it..its meant for show so I wouldn't suggest it if you live in areas that doesn't have city lights. stay with oem or go with HID...rarely use high beam so I didn't really care. If you mean if others looked at it and you high beam them, you'll definitely see the difference which is just whiter haha.
Old 01-03-2012, 08:37 AM
2012 TL SH-AWD
Zelaya's Avatar
Thanks. Do you mind me asking how much your kit cost? Do you have any DRL error code?
Old 01-03-2012, 08:42 AM
23109VC's Avatar
sniffles-
did this LED bulb you put in totally remove the halogen high beam bulb??
from your posts above, I assume you meant that by doing this, you essentially lost your high beams???
Id be interested in some way to redo the DRLs, but I don't want to lose the high beams. on one of my prior cars, a volvo, there was a small manual switch that allowed you to turn on/off the DRLs. i can't believe acura didn't give us a way to turn them off!!!
is it expensive/hard to convert the high beams / DRLs to HID?
Old 01-03-2012, 08:46 AM
Sniffles's Avatar
The kit is about $59.99 and it comes with the DRL no error harness. So I don't have any error. The resistors get hot so attach it to metal. You can buy it via their ebay account which saves you tax and shipping =)
http://www.ebay.com/itm/9005-LED-Hig...item1e6409fdc9
Ebay #- 130527395273
Follow this install from a honda civic. It shows how to connect the harness better than the instruction from IJDM. If you do end up getting it, just be careful installing the LED if you don't remove the battery. The bulb are a tight fit and if you angle it wrong going in and get frustrated trying to tighten it, you can snap the led from the base which I did =( Otherwise, its pretty easy and comes out very nice! No more yellow drl!
http://www.8thcivic.com/forums/do-yo...tallation.html
Old 01-03-2012, 08:50 AM
2012 TL SH-AWD
Zelaya's Avatar
I know on my BMW the dealer disable running lights per my request but don't know if Acura can do that. I wonder if I do a HID on my high beam and if the DRL can reduce the watts
Old 01-03-2012, 08:51 AM
Sniffles's Avatar
Originally Posted by 23109VC
sniffles-
Correct, I lost my high beam but since I never use them, I don't think it matters too much since I also have the OSRAM Cool Blue 5000k low beam. The LED replaces the 9005 high beam/DRL bulb.
It is funny that there isn't a switch for the DRL but I don't care about it since I have white Leds so I want my DRL on every chance I get haha. Hid kit for 9005 shouldn't be too expensive..you can always buy it via ebay "xentec" for $32.99 and they work fine or go with better named brands for more. If you use high beam, I would not suggest LED and suggest go for the HID. You'll get the best of both world =)
Old 01-03-2012, 08:55 AM
Sniffles's Avatar
Oops, forgot about the HID and DRL. I assume it should but I doubt it. Even when I had 8000k low beam, I never used my high beam. I just turned on my 3000k HID fog haha. Now, with 5000k OSRAM, i def don't need high beam!
Old 01-03-2012, 08:59 AM
2012 TL SH-AWD
Zelaya's Avatar
Thanks, actually they're having a 15% off if you spend $100.00 or more. I placed a order last night for my nephew so I may send them a email to add this kit to the order. Do you have a picture during daytime just to see how bight it look with the RL.
Old 01-03-2012, 09:04 AM
Sniffles's Avatar
I'll go take some pics but the last time I tried to take it in the morning, it showed the LED flickering through the camera when it really isn't through the naked eye =/ I'll try again since I am going out!
Old 01-03-2012, 09:17 AM
Sniffles's Avatar
Here it is with DRL and High Beam on. Kinda sunny out today so idk if it helps
oo7spy (01-03-2012)
Old 01-03-2012, 09:40 AM
2012 TL SH-AWD
Zelaya's Avatar
Thank you for the photos.
Old 01-03-2012, 11:31 AM
oo7spy's Avatar
Great look Sniffles, and thanks for the pics.
Not to be a downer or anything, but the exact same setup can be had for <$10. I had bought almost exactly the same bulbs on eBay, except H11 for the fogs, for $8 shipped. The code can be circumvented by a single high power resistor on either high beam. Usually the LED bulbs have a resistor anyway, so it is possible an external one is not needed. If it is needed, Radio Shack has some for ~$2.
I understand it is nice to be able to buy something complete and ready to plug in, but I want to let everyone know that this seller is making $50 off of each one of these he sells. Regardless, I am glad someone has done this mod because this question comes up rather frequently.
On a different note, where did you buy the Osram 5000k bulbs, and how much did they cost? These will be my replacements when my factory bulbs die.
Old 01-03-2012, 11:50 AM
Sniffles's Avatar
Good to know! I don't trust myself so I rather pay a little extra for the comfort of knowing it's suppose to work haha.
The Osram 5000k I bought it from motivemods. Only place to buy them..Plus, use "HIDPLANET" and you get $65 off! Found the coupon thru a infiniti forum. Total was $250 but after coupon, it was $195. I had to wait an extra week since he ran out and had to order more. Buy it before the coupon ends since idk if it still works or not
Old 01-03-2012, 11:52 AM
2012 TL SH-AWD
Zelaya's Avatar
Gracias compadre. You just save me some loop. I still will need to hire someone to install those resistor because I can't do it myself.
Old 01-03-2012, 11:54 AM
2012 TL SH-AWD
Zelaya's Avatar
What so special about the Osram 5000k besides been a little brighter than 6k. My 2012 resolution is don't spend too much mula as 2011 left a huge hole in my pocket, hahahahaha
Old 01-03-2012, 12:07 PM
Sniffles's Avatar
For sure visibility. I am coming from 8000k so I 5000k improved my driving at night signifcantly. Also a whiter and the cut off line are more precise! Beam is wider but maybe thats cause i had almost none when I was running 8000k. $195 isn't cheap but it seems you already done your mugen kit, coilovers..these bulbs shouldn't do too much damage =) Meanwhile, I have to decide Mugen or Aspec..then coilovers and rims =(((
lkoszela (04-17-2012)
Old 01-03-2012, 12:36 PM
2012 TL SH-AWD
Zelaya's Avatar
I'm broke between Mugen or Aspec I'd say go with Mugen all around
Old 01-03-2012, 12:43 PM
2012 TL SH-AWD
Zelaya's Avatar
Are this the one you order Osram
Old 01-03-2012, 12:49 PM
Sniffles's Avatar
I was thinking Mugen front since the sides and rear aren't big differences...but will it flow is the question haha.
Bulb is OSRAM cool blue intense xenarc d2s
Old 01-03-2012, 01:21 PM
2012 TL SH-AWD
Zelaya's Avatar
The promotion code expired on 12/31/2011.
In regards to the Mugen kit, side and rear is completely differenty from Aspec but I guess is all about preference. Look at thread and see yourself
Old 01-03-2012, 01:48 PM
oo7spy's Avatar
Con mucho gusto. Like I mentioned, you may not need the external resistor at all b/c the LED bulbs usually have them. I would try without it first. If it is needed, you will only need to connect it between the positive and negative wires on one of the high beams. Resistors are not polarized, so it does not matter which way it is connected.
If you do end up buying one, the only thing to consider is the power rating. Since P=V^2/R, and V=12 for the highbeams, you resistor needs to be rated for 144/R Watts. I have found a 100 ohm resistor does the trick, so if you get a 1.5W 100 ohm resistor, you will be fine. I am sure the resistor could be higher, but I have only tried 100. As long as the power rating is in-line with the calculation, you will not have any melting parts in your engine bay.
Old 01-03-2012, 01:59 PM
2012 TL SH-AWD
Zelaya's Avatar
Thanks man. I think I've a set laying around the garage. Just need to look for them. Keep you guys posted.
Old 01-03-2012, 02:01 PM
Sniffles's Avatar
I am sure a code will pop out again!
Its just so much $$..I got till spring to figure it out =)
Old 04-12-2012, 06:37 PM
Tony Torque's Avatar
So I can install Hids in for my highbeams and they will still work as DRLs???
Old 04-12-2012, 06:58 PM
Sniffles's Avatar
Originally I thought you could...but they only have a harness for the 9006 bulb and none for the 9005 DRL/HID =(
Old 04-12-2012, 07:43 PM
Oh okay so I guess it's LEDs for me then. I replaced the oem bulbs with some blue ones and they still look yellow due to the low wattage :-(.
I never use highbeams so I'll be good.
Old 04-12-2012, 08:15 PM
Sniffles's Avatar
Ya! I have the 68 led one but I don't even use it anymore since I have halos and it has been disabled...I could sell you my set with 3 led instead of 2 and the harness(with a slight burn mark but its not affecting anything) for $40 shipped?
2 led only been used for like a month and the other one is new...I had to order another set of led since I broke the led while installing since they're fragile and the opening is pretty small...Lmk!
Old 04-12-2012, 08:48 PM
Okay sounds good I'll take it as soon as I get back from my road trip to Florida.
Old 04-13-2012, 06:19 AM
Sniffles's Avatar
Ok...another guy is interested in it too so let me know asap!
Old 04-13-2012, 07:30 AM
2012 TL SH-AWD
Zelaya's Avatar
Hello Sniffles, I wish I would have known you were selling your led kit. I never bought the kit you purchased and I'm still have the error dash message which is a little annoying so if one of your buyers fake on you shoot me a pm. I really need the wiring but it won't hurt to have extra led bulbs.
Old 04-13-2012, 09:28 AM
HEAVY_RL's Avatar
Hell, if everyone else is buying it, I want it too!!
Old 04-13-2012, 09:30 AM
2012 TL SH-AWD
Zelaya's Avatar
Get it away Heavy I asked first
Old 04-13-2012, 09:43 AM
EL19's Avatar
I had to snatch this up guys
Old 04-13-2012, 09:48 AM
HEAVY_RL's Avatar
No way, sniffles put all of out user names in a hat... the one who secretly sends you paypal first should get two chances in the hat LoL
Old 04-13-2012, 11:29 AM
Sniffles's Avatar
Got the $$ in paypal :0
Quick Reply: LED Running lights
