Notices
Just purchased a 2011 RL, have questions.
Old 06-11-2019, 03:39 PM
New Member
Ive been looking for a low mileage last-generation RL for about a year. I finally found the right car and pulled the trigger on a super-clean 2011 RL Advance with under 50k. It is replacing my '09 Accord V6. One of the things I liked about the car is it has a full service history from Acura. The previous owner had the dealer replaced the lower control arms at 42k miles because the tech said the ball joints were worn. It was a $1k repair. Is it usual for ball joints to need to be replaced that soon? I have 90k on my V6 Accord and haven't needed any front end work, although I know it is a lighter car than the RL..
Thanks!
2011RL is offline
Old 06-12-2019, 10:57 AM
Registered Member
truonghthe's Avatar
congrats on the purchase, its uncommon to replace the ball joints at 42k miles (most likely that the PO ran over something) and yes the ball joint is pricey on the RL. You have to replace the entire control arm, the lower arm is like $500 per side.
truonghthe is offline
Old 06-13-2019, 11:57 AM
Registered Member
rl015's Avatar
If you are going for OEM parts and dealer to do the work, it will be pricey no matter what you do to your car lol
Rockauto.com has variety of good aftermarket parts. In the case you need to get control arms replaced, I did replace all in front (upper and lower) and it was not super expensive - I did not go with OEM fyi.
rl015 is offline
Old 06-13-2019, 02:14 PM
New Member
Thanks for the responses. The previous owner had the work done when he owned it. He was the general manager of the Acura dealer, so I'm sure he got a good deal on the parts and labor.
I didn't think it seemed normal for the ball joints to only last 42k miles.
2011RL is offline
nana2three
1G & 2G MDX Discussion (2001-2013)
10-22-2013 08:23 AM
AnhTuyetTSX
Second Generation TSX Discussion (2009-2014)
08-05-2013 09:22 AM
rock938
Second Generation TL (1999-2003)
04-07-2010 03:45 AM
LDai1219
Third Generation TL (2004-2008)
07-20-2007 07:03 AM
Fenderbender
02-09-2007 12:19 PM
Quick Reply: Just purchased a 2011 RL, have questions.
