I-004: Now you can play music using Bluetooth!
Old 11-25-2015, 11:34 AM
  #41
rlerman's Avatar
the install should be very simple, about 2 minutes. simply unplug the correct harness (should be obvious) from the XM unit in the trunk and plug the new one in and off you go.
Old 12-06-2015, 08:16 AM
  #42
MyAcuraRL's Avatar
Location: Indianapolis (Motor Sports Capital of the World)
Originally Posted by beekermartin
Edit: Opps. I misread your post.
So XM1 is for streaming bluetooth music and XM2 is for listening to XM?
Yes you are correct. I will try to post pics or video.
Old 12-06-2015, 08:23 AM
  #43
MyAcuraRL's Avatar
Originally Posted by woodek
Im getting ALOT of "bleed through" XM 1 channel music/commercial with my Grom installed Bluetooth unit. I went through the process of removing the stereo unit to install the it. It works, but is Very buggy and the XM channel can be heard a little in the background while playing my music from my iPhone. Actually a lot.
Thinking of getting this unit and installing it in the trunk. Anyone have install pics? Also, how clear is the sound and how dependable is the connectivity? The Grom is pretty bad even with the latest patch (and after pulling the stereo twice!) and connectivity is hit and mostly miss.
The USA Spec unit works great with no interference. Mine is attached to my wire harness from the older non-Bluetooth unit (USA Spec pa-15 Acux) model and I also connect a usb flush mount charger to my center console like the 2009 model.
woodek (12-07-2015)
Old 12-06-2015, 09:08 AM
  #44
MyAcuraRL's Avatar
New USB & Aux adapter in console
Bluetooth working on XM1
woodek (12-07-2015)
Old 12-06-2015, 12:34 PM
  #45
beekermartin's Avatar
Why install the USB? Does it play music from an iPod or is it just for charging? According to the specs it is just for charging. If it actually works with an iPod that would be a nice bonus.
Old 12-11-2015, 03:11 PM
  #46
MyAcuraRL's Avatar
You can use the "Aux" option to play iPod and the USB is for charging only.
Old 01-04-2016, 09:44 AM
  #47
FoxRL's Avatar
My model doesn't have the XM option (Canadian)
Booooooooooooooooo me
Old 01-06-2016, 07:41 PM
  #48
kcjohnnyboy's Avatar
this is nice! thanks for letting us know about this option. this is way better than tearing out the center console to install.
Old 01-07-2016, 12:18 PM
  #49
deepdezal's Avatar
If your car has a 1/8 audio in jack, you can try this.
Robot Check Robot Check
Old 01-28-2016, 03:10 PM
  #50
DatRL's Avatar
just installed mine the other day. works like a charm! once installed it takes about 30 seconds to pair your phone then just play your music through XM1.
install is pretty simple. open the cover for the spare in the trunk. pull straight up on the plastic cover that's over the trunk latch. peel back the trunk liner on the driver side. you'll see the silver XM module behind the quarter panel. just plug in the USA Spec and put your trunk back together!
projektvertx (01-28-2016)
Old 03-20-2016, 10:27 AM
  #51
not_a_doctor's Avatar
USA Spec, Now no more XM...
So I recently installed the USA Spec bluetooth adapter seen here:
Amazon.com: USA SPEC Acura Bluetooth Interface with XM/ NAV Traffic BT45ACU: Cell Phones & Accessories Amazon.com: USA SPEC Acura Bluetooth Interface with XM/ NAV Traffic BT45ACU: Cell Phones & Accessories
and it works great for audio through bluetooth...however, I no longer have an XM channel. Both channels 1 and 2 are bluetooth inputs. I contacted the seller and received no reply.
All the dip switches are correct per the instructions.
Anyone know of a fix or experience this on their own RL?
Old 03-20-2016, 11:41 AM
  #52
JJones91's Avatar
Did you have to use the microphone that comes with it? Or can you still use the microphone thats integrated inside the car?
Old 03-21-2016, 11:40 AM
  #53
Gotta use the microphone that came with it. Kind of annoying, but it works.
Old 03-21-2016, 08:55 PM
  #54
oo7spy's Avatar
Received 7,244 Likes on 4,855 Posts
I'm merging this thread into the first thread about this device. At least two other members have it installed, so hopefully they can chime in.
Good luck.
not_a_doctor (03-22-2016)
Old 03-29-2016, 12:19 PM
  #55
HEAVY_RL's Avatar
Received 1,038 Likes on 844 Posts
The device is malfunctioning or you put it in wrong.
not_a_doctor (03-29-2016)
Old 03-29-2016, 05:19 PM
  #56
oo7spy's Avatar
Greg!!!
HEAVY_RL (03-30-2016)
Old 03-29-2016, 05:23 PM
  #57
projektvertx's Avatar
I was starting to wonder where Heavy was lol
Old 03-30-2016, 07:40 AM
  #58
HEAVY_RL's Avatar
Ive been lurking, reading the same questions and answers waiting for oo7 to burn the place down and keep his stapler.
The following 3 users liked this post by HEAVY_RL:
oo7spy (03-30-2016), projektvertx (03-30-2016), teh CL (03-30-2016)
Old 03-30-2016, 09:53 AM
  #59
oo7spy's Avatar
If they keep asking the same fucking questions in new threads, the flames might just spread.
Old 03-30-2016, 10:37 AM
  #60
teh CL's Avatar
Old 03-30-2016, 11:40 AM
  #61
HEAVY_RL's Avatar
Well if you need a rogue, douchebag, power hungry mod to kick them around you know how to reach me.
Old 03-30-2016, 10:24 PM
  #62
tofusensei's Avatar
Definitely something wrong with your unit, as I still have XM along with the bluetooth.
Also I do not believe you have to use the included microphone for calls. You can still use the Acura Handsfree Link. I can verify this tomorrow.
Old 04-08-2016, 06:16 PM
  #63
MyAcuraRL's Avatar
You do not have to use the mic. You can use the Acura RL built in using your Bluetooth and Phone
Old 04-10-2016, 04:50 PM
  #64
definitely was a bad unit. Ordered another one and the problem resolved..although the bluetooth reception is now quite weak..ugh.
On the upside, all the features have been unlocked with the XM. Love the 1-6 button shortcuts. And, on the mic topic, there are a couple options. If you install the included mic, you can always switch your phone to the car's built in speaker. (Just note that sometimes the phone doesnt connect, and also that the included mic differs between sellers. The first one was terrible, but the second one is almost as good as Acura's.)
Or, you can skip the mic installation. But, with this option, you will need to always manually switch to Acura's system or speaker. I do not believe your phone will know that you only want the adapter's bluetooth connection for streaming, and not calls.
Old 04-17-2016, 01:09 PM
  #65
MrKev's Avatar
Anyone with the old usaspec where the iPhone connector is for the iphone 4, used an adapter converter to iphone6 that actually works for audio and charging?
Used a few that works for a short time then becomes junk
Old 04-17-2016, 02:28 PM
  #66
oo7spy's Avatar
Apple's 8 pin to 30 pin adapter uses proprietary hardware and software to convert the audio signal. The 30 pin has an analog line out that doesn't need decoding. The 8 pin has a bidirectional, differential data bus that has to be decoded and converted to analog via a DAC. I don't believe any third party vendors have a solution for that. I have Apple's cable adapter and it works as expected. They also sell an adapter without cable for $10 cheaper I believe.
Old 04-30-2016, 03:56 PM
  #67
5th Gear
sorcer7's Avatar
I'm have to try out the usa spec I've been looking for something like that
Old 05-02-2016, 07:49 PM
  #68
MayorMcCheese's Avatar
I got my USA Spec today - paid 165 on ebay.. Im in so happy I finally have this, install time took 2 minutes, for me I have my rear camera wired into the XM unit so I thought the USA spec would interfere and im happy to say it doesn't - music quality is awesome, I used an FM transmitter and it was good but nothing like usa spec
The following 2 users liked this post by MayorMcCheese:
teh CL (05-03-2016), woodek (05-11-2016)
Old 05-09-2016, 07:06 AM
  #69
5th Gear
DreamFlagship's Avatar
Friends have a cassette player and bluetooth adapter to connect the stick USB is possible to set in RL?
Old 05-11-2016, 12:56 PM
  #70
woodek's Avatar
This thing is a dream. Connects immediately - every time, clean sound and easy install.
Even after the latest update and version, My GROM installed unit (that I yanked the front stereo unit out for) NEVER connected - unless I manually connected through the Bluetooth settings in my phone, had TONS of bleed through from the XM channel and of course, was a pain in the ass to install.
Thanks USA Spec!
oo7spy (01-23-2017)
Old 01-23-2017, 01:07 PM
  #71
Ratheruneeq's Avatar
So im going to finally try and have this installed along with my JL 12 and amp from my old legend...
My question is, where are people having this interface mounted in our cars?
Before anyone mentions it, i tried ordering the kb2 face plate from inside the armrest but apparently they are discontinued or.... "on back order"
just wanted to know if there's a preferred location in terms of convenience and cleanliness.
Thx in advance.
i had posted this in the wrong thread but after reading this im not sure the one i have has been described here (correct me if im wrong)
What exactly needs to go in the trunk?
Old 01-23-2017, 01:48 PM
  #72
oo7spy's Avatar
The whole unit is designed to go in the trunk at the XM module. If you want the USB or Aux functions, you will need to run a USB or 3.5mm cable from the trunk to the cabin.
Ratheruneeq (01-23-2017)
Old 01-23-2017, 02:45 PM
  #73
Wow thanks for clearing that up. I thought the ones that need to be in the trunk were the ipod versions. I was thinking i needed to dissasemble my console and behind the headunit. So all im doing is pulling back the trunk liner and plug and play?
Old 01-23-2017, 02:53 PM
  #74
mgmny's Avatar
Great timing! My BT45-ACU unit is arriving today by USPS. I've been waiting for the mailman all day, but he usually arrives around 4pm. I'll photograph the install if i get it in no problem. Other users seem to say it's simple though.
Old 01-23-2017, 03:36 PM
  #75
Haha! Nice, ive had mine for a almost two months and wasnt sure how to approach it, plus with the weather and all... im gonna get this setup wednesday (next day off) ��✊
Old 01-23-2017, 07:11 PM
  #76
Which side of the trunk is the xm transmitter? I just got home from work, in so anxious for bluetooth audio that im bout to do this in the dark and rain ������ fucking cds! Gtfoh!
Old 01-23-2017, 08:38 PM
  #77
The XM module is on the drivers side inner lining of the trunk
oo7spy (01-23-2017)
Old 01-23-2017, 09:07 PM
  #78
mgmny's Avatar
Yeah, I was going to take photos for you, but it was super simple. It worked like a charm right when I started it up, too.
Hardest part was getting the trunk net hook back in!
Old 01-24-2017, 07:00 AM
  #79
Can you guys tell im electronically illiterate yet? Wtf am i missing here, i cant see how this plugs into any of that.....
Old 01-24-2017, 07:14 AM
  #80
Im almost convinced i have the wront unit... i pulled out both of those male plugs and neither of them match my female or male tips on the bt module...
