Honda Transmission Fluid Exchange Machine - AcuraZine - Acura Enthusiast Community
Notices
Old 02-12-2018, 02:44 AM
Registered Member
Hi!
I just got a part replaced on the RL - AC fan motor - and they (the Honda dealership)reported back that the transmission fluid is dirty. Im at 92k and plan on driving a long distance within the year so id like to get a flush anyways. I was reading the 3x3 flush is best,but Honda offered thier service that includes a "machine" and some "cleaner". Here is what they wrote:
"Using the state of the art machine, one of our trained technicians will use a safe and effective cleaner to dissolve and suspend the varnish and gums in the transmission, valve body, torque converter, pan filter element, transmission lines, and transmission cooler. The technician will then flush the entire unit of all old fluid and suspended debris, and install new transmission fluid. "
Does anyone know if this machine is worth it? Should i go with this service or specifically request a 3x3? Any thoughts would be awesome
nickelrw87 is offline
Old 02-12-2018, 08:33 AM
Registered Member
horseshoez's Avatar
Do not under any circumstances have the machine flush your transmission; instead, have a 3x3 fluid replacement done. Your transmission will thank you.
horseshoez is offline
Old 02-12-2018, 09:31 AM
Administrator
Ron A's Avatar
Originally Posted by nickelrw87 View Post
i just realized this is in wrong sub cat
Thread moved.
Ron A is offline
Old 02-12-2018, 09:35 AM
Registered Member
horseshoez's Avatar
I just checked one of my Honda Owner's Manuals and this is what it says regarding "flushing" the transmission:
To thoroughly flush the transmission, the technician should drain and refill it with Honda DW-1, then drive the vehicle for a short distance. Do this three times. Then drain and refill the transmission a final time.
Old 02-13-2018, 01:44 AM
Registered Member
got it. I will not be letting them touch it with the machine. 3x3 it is! I may just try this myself
Old 02-13-2018, 05:58 AM
Registered Member
What is proper procedure when you are doing 3x3 drain?
Bostech is offline
Old 02-13-2018, 07:18 AM
Registered Member
horseshoez's Avatar
Drain the transmission, refill with three quarts, drive a bit, repeat the procedure two more times.
The Following User Says Thank You to horseshoez For This Useful Post:
projektvertx (02-13-2018)
Old 02-14-2018, 05:50 PM
Registered Member
truonghthe's Avatar
in the RL its more like you will have to do it 5 times because each time only 2.5 quarts come out.
truonghthe is offline
Old 02-19-2018, 10:28 PM
Registered Member
i got 2.9-3 last time on ramps
HDNBenjamin is offline
rich9
Second Generation TL (1999-2003)
08-24-2011 09:38 PM
idkjai
Third Generation TL (2004-2008)
08-13-2009 12:16 AM
msvara
2G CL Transmission Recall Q & A
04-01-2006 10:45 AM
cl-baller201
First Generation CL Discussion (1997-1999)
11-19-2004 11:28 AM
Quick Reply: Honda Transmission Fluid Exchange Machine
© 2018 MH Sub I, LLC dba Internet Brands
