H-001: Maintenance Indicator
Still a newb, after reading thru the manual I understand the car will basically tell me when regular maintenance is needed (oil changes, etc) by lighting an indicator. How do I reset this if I am getting the work done at an independent shop that is NOT an Acura dealer?
________________________________________
1. Turn ignition on (II position)
2. If the oil life minder is not displayed, press the SEL/RESET botton on the steering wheel repeatedly until it is
3. Press and hold the SEL/RESET button until reset mode appears in display (about 15-20 seconds)
4. Use arrow up/arrow down to select reset
08_UA7_Gr33k
02-11-2016 02:17 PM
