THE GARAGE: Helpful 2G RL Info
CLICK HERE TO OPEN AND
SEE THE FULL LISTING OF TOPICS FOR THE 2nd GENERATION RL
BUT FIRST, READ THE REST OF THIS PAGE IF YOU HAVEN'T ALREADY DONE SO.
Use " Ctrl + F " (pc) or " Command + F " (mac)to quickly search keyword in this thread
CLICK HERE TO "SEARCH" THE FORUM
- Thinking about Purchasing an Acura RL? "Must See RL Introduction Video"
- 2G RL TSB's (Technical Safety Bulletin)
- Acura ServiceNews Bulletins
- Acura Accessory Installation Instructions
- Owner's Manuals-All Acuras and Hondas since 1990 You can register your vehicle at the linked site and open the Owner's Manual. However, you cannot save a copy because the link to the site has to be open for the PDF to work.
- Acura RL Service Manual Courtesy Mark1980
- List of Acura Dealers
- BAD POST REPORT: Please read this before you click on that little triangle
- Acura RL Media Archives/Reviews
- Acura RL Specfications from Acura/Honda News
----2011 Acura RL - Introduction
----2011 Acura RL - Features
----2011 Acura RL - Specifications
----2010 Acura RL - Powertrain
----2010 Acura RL - Body
----2010 Acura RL - Chassis
----2010 Acura RL - Interior
----2010 Acura RL - Safety
----2010 Acura RL - Introduction
----2010 Acura RL - Features
----2010 Acura RL - Specifications
----Acura Achieves Historic First in Crash Test Ratings
----2009 Acura RL - Introduction
----2009 Acura RL - Features
----2009 Acura RL - Specifications
----2009 Acura RL - Powertrain
----2009 Acura RL - Body
----2009 Acura RL - Chassis
----2009 Acura RL - Interior
----2009 Acura RL - Safety
----2008 Acura RL - Introduction
----2008 Acura RL - Features
----2008 Acura RL - Specifications
----2008 Acura RL - Powertrain
----2008 Acura RL - Body
----2008 Acura RL - Chassis
----2008 Acura RL - Interior
----2008 Acura RL - Safety
----2007 Acura RL - Introduction
----2007 Acura RL - Features
----2007 Acura RL - Specifications
----2007 Acura RL - Powertrain
----2007 Acura RL - Body
----2007 Acura RL - Chassis
----2007 Acura RL - Interior
----2007 Acura RL - Safety
----2006 Acura RL - Introduction
----2006 Acura RL - Features
----2006 Acura RL - Specifications
----2006 Acura RL - Powertrain
----2006 Acura RL - Body
----2006 Acura RL - Chassis
----2006 Acura RL - Interior
----2006 Acura RL - Safety
----2005 Acura RL - Introduction
----2005 Acura RL - Features
----2005 Acura RL - Specifications
----2005 Acura RL - Powertrain Part 1
----2005 Acura RL - Powertrain Part 2
----2005 Acura RL - Body Part 1
----2005 Acura RL - Body Part 2
----2005 Acura RL - Chassis
----2005 Acura RL - Interior Part 1
----2005 Acura RL - Interior Part 2
----2005 Acura RL - Safety
- What inspections before delivery of Car??
- Asking Good Questions
- How to post your favorite pics & Avatar???
- RL Owner Sign In
- Cool "finds" and features of the RL (Did You Know...?)
- Known RL Problems and Quirks
Important Recall Information
TSB 10-047: Safety Recall: Master Cylinder May Be Leaking
Background
A cup seal in the master cylinder is sensitive to the type of brake fluid used in the brake system. If the brake fluid is replaced with anything other than Acura (or Honda) Genuine DOT 3 Brake Fluid, and the brakes are manually bled, the cup seal may twist in its retention groove and create a small leak. The brake fluid can then leak into the brake booster, and the brake system indicator will eventually come on because the brake fluid level is low.
If the client continues to drive the vehicle without refilling the brake fluid reservoir, they may notice the brake pedal feels low or spongy. The client should not rely on refilling the brake fluid reservoir to address the problem. A prolonged leak would eventually cause one of the two brake system hydraulic circuits to fail.
Background
TSB 07-061: Safety Recall: 2005–08 RL Power Steering Feed Hose Leak
Background
Prolonged high under-hood temperatures may cause the power steering hose to deteriorate prematurely and may cause the hose to crack and leak power steering oil. Oil leaking onto a hot catalytic converter will generate smoke and possibly lead to an under-hood fire.
Background
TSB 07-017: Safety Recall: Fuel Pump Relay May Cause Engine No-Start or Stalling
Background
A manufacturing fault with the fuel pump relay (PGM-FI Main Relay 2) could cause a coil wire inside the relay to break. If this happens, the fuel pump will not operate and the engine may not start. If the relay fails while driving, the engine may stall without warning and a crash could occur.
Background
Tell Us What You Think Of the 2G RL Garage!
Version: 06.07.11
The following 2 users liked this post by csmeance:
Kovi (02-10-2015),
Snowdonuts (12-23-2016)
