G-028: Need help with reverse lights replacement?
I can't seem to find how to replace the reverse lights. Does anyone know where I can find a DIY or guide me in the right direction, maybe a step by step or pictures?
I was surprised to find out you have to remove the entire taillight assembly when I installed my new reverse lights. I've never had to remove an entire assembly to replace a bulb before. In some ways it's easier because you don't have to remove the carpeting in the trunk to get to the back of the bulbs...on the other hand, those clips on the trim pieces are a bitch.
Nope, tail light is held on by a few bolts. Here are good instructions. They are for the turn signal but the idea is the same.
Rear Turn Signal Replacement Acura RL (2005-2008) - 2008 Acura RL 3.5L V6
Please do a search before making a new thread. Not only will you likely find the answer you need, but it will help confuse others in the future.
Merging threads.
Merging threads.
