Front caliper on rear
I searched and have not found anything on this. I know Civics, Accords etc install the RL caliper with a bracket however, has anyone looked into or know anyone who's looked into installing the front caliper on the rear rotors? Does it look worth it/possible? Anyone have any info on this?
Why?
Lol for a minute I though I was reading a post on FB car group lmao. Yes Crab boi is correct for this case 4 pistons vs 2 pistons or single piston.
It's all about looks as opposed to braking performance. If I wanted superior performance I would simply get a BBK and call it a day but since I have these calipers and they certainly look better than the stock rear, no harm in asking right?!?
That being said it can work but some work, possibly more than its worth, would have to be done . I changed my timing belt/alternator yesterday and took a look at it while I was doing work on the car.
Latent car nut
Received 2,005 Likes
The front rotors will not fit for a number of reasons:
- For starters, the font rotors will not fit on the rear, not even freakin' close; this means sticking with the stock rear rotor size.
- The rotor offset from the inner face of the wheel is more than an half inch deeper on the rear brakes.
- The rotor diameter on the rear rotors is four-tenths of an inch smaller.
- I don't have the diameter measurements of the two hats, but typically the hat diameter on the rear rotors is significantly larger due to the need to house the parking brake shoes.
- A smaller diameter overall size combined with a larger diameter hat means a MUCH thinner friction surface, one so thin the front caliper/brake pad combination wouldn't come anywhere near fitting.
- Then there is the rotor thickness; the front rotors are nearly a half inch thicker than the rear rotors; try putting rear rotors inside the front calipers, and the pistons will blow right out of the caliper housing.
do it!
Latent car nut
Latent car nut
Still won't work.
Latent car nut
No, not unless you decide to do without a parking brake.
Latent car nut
Latent car nut
If you want a four piston caliper setup at all four corners, there are aftermarket kits which will achieve your goal for (last time I checked) about $2,500.
Latent car nut
Assuming OEM 17" wheels, there isn't enough space between the outer diameter of the hat and the inner diameter of the wheel rim. That said, I suppose it would be possible to grind down the gutted caliper so clearance can be achieved.
sparc
01-06-2019 07:43 AM
JDAAcuraTL
08-22-2017 09:07 PM
beekermartin
08-27-2014 06:54 PM
lookinco
09-04-2006 04:27 PM
NSX-Tuner
07-07-2004 05:47 PM
