fog light question..
I have searched and didn't find my answer.
Question: Does the 2006 Acura RL share the same fog light with another Acura vehicle?
Ie: rsx, tsx, tl
Obviously different brackets...
Ie: rsx, tsx, tl
Why don't you compare the results from here: Lamp Replacement Guide Home
FoxRL (02-10-2015)
Mind you I checked that site on my cell phone but it is only showing me the bulbs.
I was inquiring on the actual fog light itself as 1 of mine is cracked.
Oh, fog light assembly... I gotcha now.
Should I give you the link to Oemacuraparts.com?
FoxRL (02-10-2015)
FoxRL (02-10-2015)
They have pictures too...
FoxRL (02-10-2015)
I did look at the oemacuraparts site - which i thank them for putting pictures on - I printed some off and colored them too
06 RL: 33901-SJA-A01
07 TL: 33901-SEP-A01
06 TSX: 33901-SEC-A01
The difference is the middle section letter sequence. So I guess that answers my question. It seems the mounting hardware on some are a permanent fixture?
It seems like there are no used/aftermarket foglights for this car on the internet.
Let the search continue....
Thanks for the help and sarcasm
oo7spy (02-09-2015)
Theretrofitsource is coming out w/ LED foglights with full housing that supposedly fits the 2G RL. I would wait for it to see what they have to offer if you're not in a rush. $160 plus 15% discount isn't too bad.
FoxRL (02-10-2015)
There have been a few retrofits of Ford Fusion Fog lights into the RL, but I can't recall any other models.
FoxRL (02-10-2015)
From what I have seen on google - it looks like you need the alternative front bumper/lip in order to make it work/look nice. (Liek the mugen bumper)
That's probably true.
FoxRL (02-10-2015)
EDIT: One of the biggest issues is shrouds with my setup, you WILL NOT find a shroud that's drop in. Any shroud requires some serious modification because I attempt to mount the from the inside of the bumper if that makes sense. You make have better luck mounting something on the outside with a stock bumper.
FoxRL (02-10-2015)
" I mounted it in such a way to fit with the aspec black cutout"
soooooooooooooooo......do you have the old oem fog lights kicking around by chance lol.
FoxRL (02-10-2015)
FoxRL (02-11-2015)
Citidelx - Are you saying that I can buy a fog light from one of those models and take off its mounting hardware and add the RL mounting hardware?
I does look like you can remove the mounting hardware (judging by the photo of the member that did the glass replacement diy)
FoxRL (02-11-2015)
Maybe I'll buy one from a TL and try it out. IMO, it would be dumb of Honda (and probably more expensive) to change the whole fog light casing for different models (ie - different hole alignment, etc).
InFaMouSLink
10-27-2015 06:51 PM
sockr1
10-01-2015 01:31 AM
prox
5G TLX Problems & Fixes
09-01-2015 02:03 AM
