F-012: 09 wood console plate/cup holder installed in 05 RL
Old 03-20-2009, 02:46 AM
socal28's Avatar
Ok, first off, this is not as easy as I expected.
Just finished this and I'm only going to only show these pics for now.
I'll post more details and pics later (prob next week sometime).
In short, I had to modify the 09 console in these areas:
1. Remove bottom half of underside aux cover and remove wire/connector that it came with.
2. Shave seat heater surrounds on under side of console to retrofit 05's seat heater chrome bezels.
3. Extend aux wire from OEM connector with bend 09 aux terminals and connector. This is to be able to open and close the aux. It's still not the way I want it but fine for now until I have more time to fiddle with it.
Also had to shave the center console wall about 2" on the drivers side. This is to accomodate the aux underside housing.
Not sure if these modifications will be needed for all 05-08 RL's but this is what I had to do to make it fit mine.
More details and pics to follow. Need to sleep now.
Thanks.
The following 2 users liked this post by socal28:
joncole818 (05-10-2015), Ratheruneeq (01-05-2017)
Old 03-20-2009, 05:46 AM
2013 RL or bust
afjock21's Avatar
Sweet!
Old 03-20-2009, 06:47 AM
HEAVY_RL's Avatar
Received 1,038 Likes on 844 Posts
Very cool, thanks for posting pix.
Can I call dibs on your old one, if your aux cover isn't broken. (mine wont stay closed)
Old 03-20-2009, 07:42 AM
CFoote's Avatar
I'm in the middle of this project as well, and so far I've only shaved the console piece to get the Wood Console trim to fit properly. I haven't had time to proceed any further...
It's good to know I'll have to shave the heated seat mounts as well. Why can't they leave this stuff alone between model years
I have the same problem as you; the 12V connector is too big to work with the '05-'08 shift gate. I am going to cut that connector off and use the same connector you show in your pictures.
Still, for the money, it looks really nice and is worth the effort. Like you I noticed the color is a little off from the trim on the dash, but since one is real and the other is fake its not surprising.
Chris
Old 03-20-2009, 12:07 PM
rmjse's Avatar
Looks great, just needs a matching wood steering wheel
Old 03-20-2009, 12:12 PM
socal28's Avatar
Already have it. My next install project.
Old 03-20-2009, 12:16 PM
socal28's Avatar
I don't think you want my old one. It has some stains on it and inside the aux is dirty from previous smoker.
That's one of the reasons I went this route.
Will probably keep it in case I get rid of the car later.
Old 03-20-2009, 02:06 PM
The Doctor
UW RL's Avatar
Looks like the new wood plate is not flush with the cup holder cover, or am I imagining things?
Old 03-20-2009, 02:19 PM
HEAVY_RL's Avatar
Thanks for the reply... sorry to go off topic, but could you post a pic of the bottom of it so I can see how it locks?
I'd like to order new parts if I can.
Old 03-20-2009, 07:57 PM
socal28's Avatar
I'll try but probably won't be able to until next week sometime. Going out of town this weekend.
Old 03-20-2009, 08:35 PM
neuronbob's Avatar
Received 4,612 Likes on 2,193 Posts
Niiiiiice. That really sounds like a lot of work. Good job!
Old 03-24-2009, 05:14 PM
socal28's Avatar
Here's a couple of pics in the sun of the different constrast of the 05 wood (real?) versus the 09 wood console. Not sure if the 06-08 would be different.
The 09 wood matches pretty well with the wood shift knob accessory.
Even my OEM door versus center wood looks different...
Old 03-24-2009, 05:15 PM
getakey's Avatar
my OEM door and center wood are different as well. Looks about the same as yours.
Old 03-24-2009, 05:22 PM
socal28's Avatar
Here are some pics of my 05 OEM aux for you...
You can see in the pic below in the upper left corner of the unit is the locking mechanism (i purposely held it right before lock for this picture).
Old 03-24-2009, 05:26 PM
socal28's Avatar
Wood steering wheel going on tonight.
Will post more pics with all together.
Old 03-24-2009, 09:11 PM
HEAVY_RL's Avatar
I appreciate you circling back. Thanks!!
Old 03-24-2009, 10:14 PM
neuronbob's Avatar
Great photos, thanks!
Old 03-25-2009, 01:15 AM
socal28's Avatar
Here's a pic with the wood steering wheel now...
Old 03-25-2009, 06:20 AM
CFoote's Avatar
Steve,
Nicely done! It really does look awesome. I am going to work on this when I get home today....what exactly did you do to get the silver trim pieces around the heated seat switches to fit? Did you trim the console piece or did you trim the actual silver trim pieces?
Beyond that I also have to change out the wiring for the 12V and then I should be good to go....and finally have my car back together!
Thanks for the help,
Chris
Old 03-25-2009, 07:46 AM
unofficial HONDA rep
fredren's Avatar
nice work, but i am not a big fan of wood interiors even though i have the steering wheel and shift knob lol, but does anyone know if the 09 RL's black wood can fit? doors, dash, steering wheel etc
Old 03-25-2009, 10:45 AM
rmjse's Avatar
Looks great man! You did an awesome job on those installations. Gratz all the way...thanks for the pics
Old 03-25-2009, 10:50 AM
socal28's Avatar
Originally Posted by CFoote
Steve,
Chris
Chris,
I trimmed the underside console piece to fit the silver heated seat bezels. I just used some wire cutters to cut off some tabs.
Old 03-25-2009, 10:55 AM
JohnnyRambo23's Avatar
Wow that looks great...
Old 03-25-2009, 10:56 AM
socal28's Avatar
I'm actually not a big fan of wood either.
I mostly did this upgrade to replace worn out pieces.
Shift knob and steering wheel leather showed significant wear, console plate around the shifter had stains and aux was dirty from previous smoker, cup holder door would intermittently not close, etc.
Figured that this was a good opportunity for this project.
Old 03-25-2009, 03:18 PM
CFoote's Avatar
re: 09 Black wood trim pieces....of course it can be done but it is VERY expensive...be prepared for sticker shock
Old 03-27-2009, 02:07 PM
1stRL's Avatar
where did u get the trim
Old 03-27-2009, 03:35 PM
socal28's Avatar
There is a vendor that sales them here...
https://acurazine.com/forums/2g-rl-2005-2012-76/cup-holder-console-trim-special-713207/
But I got mine from Clint at Findlay Acura as I purchased other items from as well.
Old 03-28-2009, 04:45 PM
CFoote's Avatar
Just thought I'd mention that I finished this project today It looks great and I personally feel it really adds to the interior of the car. Well worth the effort.
Steve has outlined the tasks that need to be done, so if you follow his advice and read through this thread you should have no problem doing this project.
Now I'm curious if those pieces from the '09 door panels will fit the previous models so that you don't have to use those awkward door handles to close the door.
Chris
Old 03-28-2009, 06:42 PM
rmjse's Avatar
Chris
Would love to see some pics, if possible?
Old 03-29-2009, 02:04 AM
g0df8the12's Avatar
Nice job and looks good! I thought of doing this also. How much did you pay for the center console plate and cupholder?
Old 03-29-2009, 07:47 AM
2012 Cadillac CTS-V Coupe
GoHawks's Avatar
The doors are plood for all models, all years. The center is the only piece that is real wood, except for '08, '09 base models.
Old 04-02-2009, 06:19 PM
bnl107's Avatar
I just ordered these parts. How do I remove the original pieces to replace them? Thanks in advance.
Old 04-02-2009, 06:27 PM
socal28's Avatar
You can follow this guide from Acura, steps 9-15. You don't really need to do steps 12-13.
http://techinfo.honda.com/rjanisis/pubs/AI/BII31183.pdf
Old 04-02-2009, 08:02 PM
bnl107's Avatar
Perfect. Thanks SoCal28...
Any other hints or tips (other than what you've posted here) I should know before I begin?
I'll be sure to snap some pics during my install, too. Add to the thread.
Old 04-03-2009, 08:03 AM
CFoote's Avatar
As Steve mentioned, you need to remove a few pieces from the center console trim piece with regards to the 12V power outlet.
-- Remove the wiring harness / plug from the actual cigarette lighter;
-- In order to do the above you'll need to remove the black trim piece that surrounds the cigarette lighter underneath.....remove it and throw it away, the piece won't fit with it installed.
-- Trim the center console as Steve outlined in his pictures
-- You might want to make your own wiring harness (as Steve did) for the 12V power outlet.
It's a somewhat complicated project, but it looks really good.
I would post pictures, but I have the exact same color combo as Steve, so there's not much of a point....I even had the wood steering wheel and shift knob, so it really is an exact copy of my interior
Chris
Old 05-19-2009, 12:57 AM
socal28's Avatar
Finally created my own page for this install...
http://www.socal28.com/rl/09centerconsole.htm
Old 05-19-2009, 01:04 PM
Chas2's Avatar
Great job!
Nominated for the 2G RL DIY Project!
Got one for the wood steering wheel?
Old 05-19-2009, 01:34 PM
socal28's Avatar
Originally Posted by Chas2
Great job!
Acura has an install doc for this.
Here's a copy of it on my site...
http://www.socal28.com/rl/RL_05_WoodWheelInstall.pdf
It's fairly simple, just make sure to handle the airbag unit carefully and remember what position you took off the wheel at.
You also don't need a steering wheel puller. At least I didn't need one for the multiple times I changed mine. Just gently pull and wiggle back and forth.
Old 05-19-2009, 03:06 PM
synth19's Avatar
nice work!
Old 11-17-2009, 11:51 PM
knv8's Avatar
nice! thought i was lookin at the inside of a bentley for a minute
thinkin bout gettin a shift knob also
Quick Reply: F-012: 09 wood console plate/cup holder installed in 05 RL
