Check VSA fault code after chip key programming
2008 RL. Had only one remote and key. Tried local mechanic to reprogram newly bought chip key & remote. He could not program. Now it give fault code " Check keyless entry system"
Took car to local reputed transponder programming shop. Second set of remote and chip keys are programmed.
Keys work fine with newly added Driver 2 set.
However
a) Check keyless entry system fault code remains
b) New fault code of "Check VSA system" in orange letter on speedo display panel only with driver 2 remote
c) When tested with original Driver 1 remote, I do not get orange letters fault code on speedo display however yellow triangle exists when car is started with either remotes
Is there a way to clear the fault codes?
However
Fk no!TheyldstroyEvrthing
If some total reset was made for some reason.. you may need to do 'neutral position memorization' for the VSA to go away.
Look online, or a honda compatible scanner can do it in the options.
oh btw:
a: is that on both remotes? check remote battery.
c: the yellow triangle follows VSA. Do my previous post, the yellow triangle goes away.
angeljr8282
07-31-2018 10:49 AM
wmahmud
4G TL Problems & Fixes
41
01-03-2017 11:12 AM
piggydog
02-11-2010 11:05 AM
