charging port next to shifter
Where is the fuse for this port? It's currently not working. The only one working is the one inside the center console arm rest. Thanks in advance.
Most likely in the fuse board in the driver side kick panel. It's also possible the bezel around the shifter was removed and the wire was removed or damage and never reconnected?
I removed it to install GROM unit. But put it back the right way. No broken wires plugged it in correctly. Which number fuse is it?
There's a VERY detailed manual available on this site that has all that info in it. If you can't find it, email me at plohmeyer@woh.rr.com and I'll try to send you a download.
teh CL (10-11-2017)
