Center Console Wear
Center Console Wear
I have a 2007 with 155,000 miles and that is no typo. The only things that I have done out of the ususal brake pads, battery etc has been replacing both the drivers and passengers armrests. Now the top of my center console has begun to wear thin and get bubbles especially on the sides and a few on the top.
I have read on the forum where some have replaced with real leather and others replaced with a new console which is very expensive. It does seem strange that after 155,000 miles, the mechanics of the car are holding up and the arm rests are giving out. I am not complaining however because my guess is that these three items are alot cheaper to replace than a starter, alternator, master cylinder etc..
Two questions are those that have replaced with real leather how does it look and how much did it cost. Those that replaced the center console, did you remove just the top two hinged pads or the whole top that is hinged and tilts back. Most importantly how did you remove either of these?
Thanks,
Thanks,
Карты убийцы
You can of have to disassemble the entire unit... I remember removing the molding around the rear AC ducts in the center. It's not that hard of a job... a phillips short handle screw driver and a butter knife will do the trick.
As said the OEM is very expensive. And after I replaced it, it started to bubble again within 4 months. If and when it tears, I'l going to a shop and real leather put on.
yeah i wanna replace mine as well. i got my rl with the top already bubbling but now both of them are bubbled up and the driver side actually tore. real leather would definitely be nice
You did console only for 80$ or door arm-rests were included as well? I take it it is only console ... it seems bubbling is sun heat related since my car is not garaged and it was by 1st owner - it started bubbling more now...
Fred-
at 155k miles - what major components have you had to replace? any big ticket items or has the car held up well?
how does she drive still? solid?
it's nice to see higher mileage RLs... gives me peace of mind I've got another 100k left in my car.. as I"m only at 55k right now!
Fred-
Outside of routine wear items (tires, battery brake pads) I have had nothing replaced or repaired except both armrest and now the center console top. I am knocking on wood!!! The car looks and drives like the day I drove it off the dealer's lot (155,000 miles). My friend asks me routinely if you had to buy a new car what would you buy? My answer is always a 2009-2010 white RL. I have silver now and my wife has a silver car. Silver never shows dirt and really shines but would want something different.
23109, this is from another thread where a user was concerned about buying a high mileage used Acura.
Screw 100k! Keep changing those fluids and your car has another 250k left in it.
Not sure about the rest, but Legends (a.k.a. RLs) seem to run forever. No mileage worries whatsoever as long as the previous owner kept up with maintenance. See here:
https://acurazine.com/forums/showthr...ghlight=legend (Go to page 3 for the latest updates.)
https://acurazine.com/forums/showthr...=746000&page=2 (post 51 is where it's at!)
When Blazing sold his RL, his arm rests were still VERY jacked up so I assume it was just his center console.
Chapter Leader (Chicago)
yeah i got the same issue
mine is on the center arm rest and driver door too...
i thought i read some where a member got his re-done by his dealer and it was covered by warranty... anyone wanna shed some light into this?
i've had my center armrest replaced by the dealer when it was under warranty. dealer didn't seem to want to replace as they said it wasn't covered under the "warranty". so i pushed back and said this is unacceptable after only 35k miles. they ended up replacing it for free as a one time courtesy (whatever!). i'll take it though.
mlody
12-04-2019 02:11 PM
LogicWavelength
3G TL Photograph Gallery
33
11-01-2015 09:38 AM
InFaMouSLink
10-27-2015 06:52 PM
