Car lock question
'05 RL & '10 MDX
Car lock question
When i lock the car with handle or the fob I can hear the doors lock but it doesn't beep and the lights don't flash. I went thru the keyless entry settings and everything is still set correctly so not sure what's happened. Could it be a fuse?
mine beeps and blinks with one touch
Yes, I remember it being set in the mid, but I can't remember the options. I think you were the one that did not want your HIDs to blink - wasn't that you? So that must be an option.
found the thread and your memory better than mine, but you had the first response
https://acurazine.com/forums/showthr...ighlight=blink
'05 RL & '10 MDX
That is the way it's always been until recently. I can hit 10 times in a row and nothing. I double checked the mid and none of the settings have changed. That's why i was thinking it could be a fuse.
OP, when you exit the vehicle, lock the doors via key fob, if it doesn't beep, place the key fob far away from the car so you don't activate the auto unlock when hand is placed on handle, take a walk around the car without the fob on you trying to open all the doors. If one of your doors isn't locked, it won't "beep". My rear passenger door stopped auto locking and I noticed it when the car failed to "beep" at me. Fixed the door lock problem and the "beep" is back.
tman570
06-11-2019 07:56 AM
Hau_nguyen91
09-06-2015 12:53 PM
