Cam and crank seals at 200K - AcuraZine - Acura Enthusiast Community
Notices
Old 10-07-2017, 05:23 PM
New Member
I'm doing a timing belt change on a 2005 acura rl. for a friend. along with the timing belt, water pump, tensioner and pulleys, do you think i should relpace the cam and crank seals? without having to looked at it yet, I'd like to know if they should be replaced at this milage. new owner of a used car. no service history. Thank you.
dirtx is offline
Old 10-07-2017, 10:15 PM
projektvertx's Avatar
At that kind of mileage, I would go ahead and replace them, especially if you're planning on keeping the car. If they start leaking, you'd have to redo the whole timing belt to do the job.
projektvertx is offline
Old 10-08-2017, 03:00 PM
New Member
thanks
thank you for the reply. makes good sense. I will use oem seals. havent had much luck with aftermarket seals latley.
dirtx is offline
Old 10-10-2017, 08:29 PM
Registered Member
truonghthe's Avatar
OEM seals cost like $20 (if that much)
truonghthe is offline
Old 10-11-2017, 06:56 AM
Registered Member
frankjnjr's Avatar
Absolutely, Cheap Insurance at that mileage. You may also want to examine a couple other things, while your in there. #1. Check for any evidence of oil leaking from the oil pump seal areas. Such a leak, should be very evident, externally, and would be convenient to repair, in conjunction with the timing belt.. #2. Check the condition of the bearing, on the accessory drive belt tensioner pulley. Checking this bearing, should be done prior to releasing tension on the pulley, with the engine running, using a mechanics stethoscope. If the bearing is noisy, you may as well change it while your in there.
frankjnjr is offline
Old 10-11-2017, 10:56 PM
Registered Member
deepa1600's Avatar
Do you know part # for the seals? How hard are they to replace during timing belt installation( do more parts need to come off)?
deepa1600 is offline
Old 10-12-2017, 09:20 AM
Crankshaft seals:
91213-P8A-A01
91213-R70-A02
For some reason, I can't pull the crankshaft oil seal readily??
The Following User Says Thank You to projektvertx For This Useful Post:
deepa1600 (10-12-2017)
Old 10-12-2017, 10:13 AM
teh CL's Avatar
Crankshaft oil seal aka oil pump seal?
91212-R70-A02
Honestly.. if your at the mileage where that starts to leak, you might as well replace the whole oil pump for $130. Peace of mind > *
teh CL is offline
The Following User Says Thank You to teh CL For This Useful Post:
Old 10-12-2017, 10:14 AM
91212-R70-A02
And there you have it, me be dum dum this morning
Old 10-12-2017, 10:26 AM
teh CL's Avatar
teh CL is offline
Old 10-16-2017, 06:59 PM
New Member
thanks for all the replys. Yes I will change the seals with factory oem. and and all honda parts. Just came in the mail yesterday. The oil pump is a good idea, but since its not my car, i suspect only if its leaking behind the cover will he want to replace it. I am changing the crank seal which is in the front part of the oil pump. Thanks again all.
dirtx is offline
Registered Member
deepa1600's Avatar
Originally Posted by projektvertx View Post
Crankshaft seals:
91213-P8A-A01
91213-R70-A02
Are these same seals with different part #? Because on oemacuraparts it shows these as 2 different part no's for same seal.
Old 10-16-2017, 07:33 PM
Yup, you nailed it OEMacuraparts shows them as the same seal with different part #s
Jordy Spaur
Third Generation TL (2004-2008)
11-17-2013 08:58 PM
wetcmonkey
First Generation TL (1996-1998)
01-09-2012 08:25 PM
bpjadhav
14
10-06-2007 10:26 AM
Quick Reply: Cam and crank seals at 200K
