Comfort control system (poor heat)
Old 12-29-2017, 09:55 AM
jmcarter05's Avatar
Exclamation Comfort control system (poor heat)
2006 acura rl
Ran sensor diag. no problems shown. Have confirmed control valve open inlet out let temp at 170. Have heat on passenger side vent in manual mode with re circulation vent closed. When open no heat appears to be around 67. Drivers the same no matter what at 67. Great heat at rear vents. Toa reading appears to be only sensor out of wack with a 140 reading. Have ohm tested the drivers temp sensor and confirmed fan operation as well as ohm tested the passenger vent sensor for function as well both check out. solar sensor values appear normal with flashlight test and covering it on dash. I get a call for air conditioning in manual mode as soon as I come off high it also does the same thing in auto mode. Any help or direction would be appreciated.
joeshed
2G CL Problems & Fixes
10-31-2014 04:24 AM
simonpozi
06-25-2011 11:17 AM
ddubois
09-25-2003 07:54 PM
Quick Reply: Comfort control system (poor heat)
