AVS and Check air bag system intermittent lights.
I just picked up my second Acura RL. Boy it's a great car i'll keep for awhile. The AVS light to the right of the Exclamation triangle, also the Check AVS system that comes on in the center over 30 MPH. They reset every time the car sits for an hour. Same with the Check airbag system in the center and red airbag light on the bottom right. Could someone help me? From my knowledge this car has never been hit. Also has 160k
Jeff
Jeff
AVS or AFS? Could just need a new battery.
oo7spy (12-17-2015)
What is AVS?
Vehicle Stability Assist. You might have a faulty air bag sensor or SRS unit. If the vehicle thinks a safety system isn't functioning, like TPMS, it will force VSA on.
I would get the charging system checked.
I'm not sure about the numbers, but the air bag message just means someone or something was in the seat that wasn't heavy enough to make the air bag go off. If you delete that, it should go away. This comes on if I put groceries or something heavy up front...
Fk no!TheyldstroyEvrthing
There's no avs.
It's VSA.
It's VSA.
Yehokhanan Jackson
1G TL (1996-1998)
11-27-2015 10:48 PM
