Key position 1 - battery dies?
Old 02-29-2016, 10:52 PM
Xanthous's Avatar
Occasionally, I forget and leave the car with the key position on 1. In my old car, that would only have the effect of the ignition being on for 15 minutes and then it would turn off. I've made an effort to always turn it to 0 but days like today I walk out and the car battery is dead. Is this with everyone's RL?
Old 03-01-2016, 11:02 AM
oo7spy's Avatar
Received 7,244 Likes on 4,855 Posts
So you forget to turn off your car, it drains the battery, and you want to know if other cars would do the same if they were left on?
Destiny1217 (01-24-2024)
Old 03-01-2016, 11:11 AM
Received 8,584 Likes on 6,630 Posts
Originally Posted by oo7spy
So you forget to turn off your car, it drinks the battery, and you want to know if other cars would do the same if they were left on?
It's that kind of thrill
Old 03-01-2016, 11:13 AM
cu2wagon's Avatar
Received 7,772 Likes on 5,045 Posts
Is this a pushbutton or traditional key turn-cylinder?
Old 03-01-2016, 11:15 AM
TacoBello's Avatar
Received 4,416 Likes on 3,322 Posts
I don't even understand how you can leave the car in position 1 and blindly walk away.
how do you push button key position 1?
oo7spy (03-01-2016)
Old 03-01-2016, 11:18 AM
cu2wagon's Avatar
I'm getting there... One question at a time.
So is it safe to assume it's a traditional turn cylinder?
(off topic, but "position 1" on a push button is like how you click the little floppy disk icon so save a document... WTF is that symbol anymore? It's just what it is.)
Old 03-01-2016, 11:19 AM
TacoBello's Avatar
Foot off brake pedal, push button once, voila.
Old 03-01-2016, 11:20 AM
I'll see myself out now
Old 03-01-2016, 11:23 AM
cu2wagon's Avatar
Ah, is it one of those goofy things where you need the fob to get into the car but then there's a little switchy thing to turn for the ignition?
If so, then I'd think the switchy thing would have the traditional "0 I II Start" positions and that it would be possible to leave it in "I" without the key in the car.
And yes. That position is intended to power the accessories so it will draw power and will drain the energies from the battery.
Old 03-01-2016, 11:34 AM
oo7spy's Avatar
I went over this in the push start ramblings thread. The RL has keyless access with a mock ignition key. It is far superior to any Lexus.
cu2wagon (03-01-2016)
Old 03-01-2016, 11:37 AM
cu2wagon's Avatar
Thanks! My intuition and superior google image searching prowess was correct, it sounds like.
So the answer is... "Stop doing that".
Old 03-01-2016, 12:44 PM
oo7spy's Avatar
Yes. Stop doing that. All RL batteries will die when you leave the car on with the engine off.
Old 03-01-2016, 05:45 PM
Fk no!TheyldstroyEvrthing
RL09's Avatar
Yep. Drained mine trying to figure out the Nav & BT controls few days after i bought it.
Old 03-01-2016, 07:00 PM
Xanthous's Avatar
05 RL, keyless fob with ignition switch.
Old 03-01-2016, 07:02 PM
Xanthous's Avatar
No, I wanted to know if there was something wrong with mine because all my previous cars had an auto time out feature where it was impossible to kill the battery.
Old 03-01-2016, 07:04 PM
cu2wagon's Avatar
But on the obverse, if it *did* have the auto-off feature, there would inevitability be people complaining that they can't listen to the radio or keep their lights on for longer than xx minutes; and how it's hard to believe a luxury car manufacturer could not include that feature...
50/50!
projektvertx (03-03-2016)
Old 03-01-2016, 07:48 PM
oo7spy's Avatar
Which previous cars did you have?
What is the benefit of leaving your car on and walking away?
Old 03-01-2016, 08:22 PM
RL09's Avatar
What benefit. It's coz ppl forget it on.
I think the general op confusion is the difference in assumptions when making a car with a turn ignition and another with a button. with the button, it can be expected ppl will forget it requires one more push to turn it entirely off. With turn ignition, it's more physically obvious.
the c300 i was driving for past 3 months was a button, and i did forget it a couple of times. it turned off by itself. The RL, i leave ignition 1 on on purpose sometimes so that my son gets to keep the radio on; I've never forgotten it on.
Hope it answers the op, altho if u (op) got an rl and forgetting it in ignition 1, u need to think as to why that is happening to you.
Old 03-01-2016, 10:25 PM
oo7spy's Avatar
No shit. It's as if you haven't forgotten how a car works.
Leaving the turn key ignition in the ACC position and questioning a dead battery is equivalent to going back to a manual transmission and questioning why the car won't shift without pressing the clutch.
C'mon, man.
Old 03-02-2016, 01:00 AM
RL09's Avatar
C'mon, man.
Old 03-02-2016, 03:48 AM
Xanthous's Avatar
Had a bonneville and grand prix. Both had the option to turn the key reverse to leave the car on for extended periods of time.
As to why it happens, occasionally when I turn the car off, it sticks on 1 instead of 0. That is probably the most likely reason.
Old 03-03-2016, 01:37 PM
Blues Legend's Avatar
C'mon, man.
My S2000 does very well indeed - you just have to match the revs carefully!
I guess the Regendo has made me too lazy to use the clutch in traffic...
Shirley one just turns the key until it stops & then remove it...or press the brake, shift into park and then remove it if you're absent-minded like me.
Mind you, I've had cars where even leaving it with the engine running wouldn't encourage someone to steal it either.
Old 03-03-2016, 02:35 PM
01acls's Avatar
Lol you guys are F'ing brutal
Most of you guys are misunderstanding what op is asking.
The op is asking if the RL has a power cut off feature if the ignition is left on in the no. 1 position?
Apparently, there are smart cars with this feature but you guys go all sideways on op.
Old 03-03-2016, 03:49 PM
oo7spy's Avatar
Yes. My mom's 280Z could too, but....
STL acura
05-07-2017 03:24 PM
Dilawer
02-20-2016 06:45 PM
Comfy
01-20-2016 08:19 AM
Quick Reply: Key position 1 - battery dies?
