2G RL A/C Problems
Old 05-29-2016, 10:46 AM
  #161
Jazzy1999's Avatar
Just in time for the start of a hot Memorial Day weekend.. A/C decides to blow hot air
Old 05-29-2016, 11:35 AM
  #162
teh CL's Avatar
Check your fuses..
Mine stopped working the other day. Under hood fuse keeps blowing, need time to investigate
Old 05-29-2016, 11:45 AM
  #163
Jazzy1999's Avatar
Originally Posted by teh CL
Check your fuses..
Are all the fuses for the A/C under the hood or interior of the car?
Old 05-29-2016, 12:27 PM
  #164
teh CL's Avatar
One under the hood and one under driver side dash
Old 05-29-2016, 03:26 PM
  #165
Jazzy1999's Avatar
I had settled that is was the compressor. So I was gonna put myself at the mercy of the stealership to repair. Thought I would check the fuse under the drivers console. Pulled it out all fine, put it back in tried the A/C and it came on 40 degrees. Now I'm a little weary how long will it last for.
Old 05-30-2016, 10:06 AM
  #166
oo7spy's Avatar
Received 7,244 Likes on 4,855 Posts
Try some coffee.
Old 05-30-2016, 10:24 AM
  #167
Jazzy1999's Avatar
^^^ Not really a Coffee drinker, more so a Tea Drinker( it's the English in me ). Meanwhile update back to warm air again ��
Old 05-30-2016, 10:33 AM
  #168
teh CL's Avatar
Replace my fuse every morning to have AC
hopefully have time later tonight to finally get something done..
Old 05-31-2016, 09:44 AM
  #169
oo7spy's Avatar
I enjoy my tea too, but I find its not strong enough to curb weariness.
Old 06-04-2016, 09:51 AM
  #170
CFoote's Avatar
Jazzy your stator is probably going bad on your compressor, the stator is what starts the compressor, and there are two scenarios that can happen:
a) tech can get clutch off, replacing stator, and you are back in business
b) clutch is frozen on to compressor, tech can't get to stator to replace, you have to replace entire assembly ($$$) (whole new compressor/clutch assy)
Unfortunately my RL had a frozen clutch, so the tech had to replace the entire compressor...big bucks. Hopefully your clutch is not frozen on to the compressor, that is the moral of the story.
Chris
Jazzy1999 (06-04-2016)
Old 06-11-2016, 08:45 AM
  #171
ditchbry's Avatar
no A/C 2006 RL
Hello everyone. This is my 1st post, and although I think I know what the problem is, I'd like to see if anyone else has had a similar issue. drove my 06 RL to dinner, with ice cold air. After dinner, we went to leave, and had warm air blowing from the vents. I drove it home, and when I went back out to look at it, it was working. I figured it was a fluke. When it happened again I investigated. Both fans are running, and I have power at my compressor. I'm thinking clutch problem. Suggestions?
Old 06-11-2016, 09:57 AM
  #172
wackjum's Avatar
My 05 RL had the same problem. The compressor was fine. It was the clutch not engaging.
Also, you should post this in the RL specific forum. This is general car talk.
Old 06-11-2016, 10:10 AM
  #173
Chapter Leader (Houston)
TLDude876's Avatar
Received 1,085 Likes on 810 Posts
+1 for ac clutch and coil
Old 06-11-2016, 12:09 PM
  #174
Administrator
Ron A's Avatar
Received 1,002 Likes on 572 Posts
Welcome to the forums. Thread moved to 2G RL Forum.
Old 06-11-2016, 02:05 PM
  #175
oo7spy's Avatar
Very common issue on the RL. A search would've shown that.
Old 06-13-2016, 10:41 PM
  #176
9th Gear
littlenoodleboy's Avatar
Do you know the part # for clutch problem?
Old 06-13-2016, 10:58 PM
  #177
9th Gear
Do anyone know the 05 Acura RL part number for the stator(field coil) clutch. My AC inst working. I check all the fuses and the freon psi and everything is good. I even hear the compressor come on when I hit the AC button. but still blowing hot air. So I'm going to try DIY. Any tips,instruction,pictures would be help.
Thanks in advance
Old 06-14-2016, 12:00 AM
  #178
9th Gear
do you happen to have the DIY guide. I am having the same issue.
Originally Posted by LeftCorner
I've done 10+ of these and it only requires the stator ass'y. It's possible to do it in the car, a pair of 90° angle snap ring pliers will be your best-friend if you choose this route.
Old 06-14-2016, 05:43 AM
  #179
Jazzy1999's Avatar
correct me if I'm wrong but I believe this is the part
Old 06-14-2016, 07:16 AM
  #180
CFoote's Avatar
I mean this in the nicest of ways, but if you don't even know where to look to find the parts, you really shouldn't be attempting this job yourself.
If your compressor is turning on and spinning, then its not your compressor/stator/clutch.
Get it diagnosed properly, perhaps you have a leak in the system and it just needs to be charged. A/C systems need the proper tools and diagnosis before you start throwing parts at it.
Chris
teh CL (06-14-2016)
Old 06-14-2016, 10:18 AM
  #181
9th Gear
I dont have any leaks. There is still freon it. I use the gauge and it reads at 45 psi.
Chris
Old 06-14-2016, 10:19 AM
  #182
9th Gear
Thanks jazzy1999
Old 06-14-2016, 10:34 AM
  #183
JJones91's Avatar
My AC went out too last week. Followed by the transmission. Acura wants $7000. No thank you ill just buy my VW GTI I been after, I just have more of a reason to buy one now.
Old 06-14-2016, 10:57 AM
  #184
teh CL's Avatar
Transmission?
Old 06-14-2016, 01:13 PM
  #185
JJones91's Avatar
Transmission?
Yuppers transmission went bye bye
Old 06-14-2016, 01:45 PM
  #186
oo7spy's Avatar
The following 2 users liked this post by oo7spy:
TampaRLX-SH (06-14-2016), teh CL (06-15-2016)
Old 06-14-2016, 05:40 PM
  #187
JJones91's Avatar
Just started shifting real hard then stopped going into gear, would just act like it was in neutral.
Old 06-14-2016, 05:45 PM
  #188
Received 8,584 Likes on 6,630 Posts
low on tranny fluid? broken axle..?
Old 06-14-2016, 05:50 PM
  #189
JJones91's Avatar
Axles look good didn't see anything out of the ordinary, and the tranny fluid should be okay there's absolutely no residue under the car or around any mechanical parts, I can hear it making gear changes but it won't go anywhere unless I rev the car real high then it'll just crawl like 1mph
Old 06-14-2016, 07:48 PM
  #190
oo7spy's Avatar
Probably torque converter.
Old 06-14-2016, 09:19 PM
  #191
JJones91's Avatar
Who know's but I'm not even going to bother fixing it. To me it's not even worth the time and money along with the other issues I've been having I feel like I'd be throwing money down the drain.
Old 06-14-2016, 10:55 PM
  #192
oo7spy's Avatar
Should've sold it when it was worth $7k.
Old 06-15-2016, 08:04 AM
  #193
Jazzy1999's Avatar
Is anyone familiar with the after market or remanufactured compressors kits sold on ebay? The reliability of them, they do pale in comparison in price OEM $700+
http://www.ebay.com/itm/172176953792?_trksid=p2055119.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Old 06-21-2016, 02:30 PM
  #194
3rd Gear
Lidia Reyes's Avatar
Ac Problem
Hi, my ac compressor works but it doesn't throw any cold air. My navigation system doesn't work at all to control it and Idk if that's a problem for the ac. I put the temperature on low. I have a Acura Rl 2005. It just throws warm air. We bought a ac compressor. Need help.. Tia..
Old 06-21-2016, 03:38 PM
  #195
iSeeYouTwo's Avatar
Did you refill the refrigerant?
Old 06-21-2016, 04:50 PM
  #196
3rd Gear
Yes I did.
Old 06-21-2016, 06:11 PM
  #197
teh CL's Avatar
Check your fuses
Old 06-22-2016, 10:01 AM
  #198
3rd Gear
Check your fuses
I will, thanks.
Old 06-22-2016, 12:29 PM
  #199
oo7spy's Avatar
Most likely stator, field coil, or clutch. I can't ever remember which are separate parts though.
Old 07-06-2016, 10:29 PM
  #200
Jazzy1999's Avatar
Just replaced my stator back in business
Quick Reply: 2G RL A/C Problems
