Notices
2007 RL poor acceleration when hot
Old 04-29-2019, 05:21 AM
Registered Member
Hi
I have Acura RL 2007. I can see strange behavior. When temperature outside is quite low all works properly, When is hot outside and especially after long waiting for green light acceleration is more than poor. I am able to accelerate very slowly even pushing acceleration pedal fully.
If I keep acceleration pedal pressed in 20-30% after some hundred of meters car again starts to accelerate as usual.
I have clean air filter, properly serviced engine oil, AWD and transmission. I have new spark plugs either coils. Also incoming air temperature sensor has been replaced. Engine temperature is all the time normal - not too hot.
What could be the reason?
MarcinK is offline
Old 04-29-2019, 09:11 AM
Registered Member
deepa1600's Avatar
Maybe your brakes are sticking?
deepa1600 is offline
Old 04-29-2019, 09:14 AM
Registered Member
No. Brakes also are OK
MarcinK is offline
Old 04-29-2019, 10:31 AM
projektvertx's Avatar
Sticky throttle plate?
projektvertx is offline
Old 04-29-2019, 11:55 AM
Registered Member
Only when hot?
MarcinK is offline
Old 04-29-2019, 01:48 PM
Registered Member
deepa1600's Avatar
What's the mileage on the car? What octane fuel you use? May be the o2 sensors are bad or get your fuel system pressure checked. It could be as simple as a nad fuel or maybe the cat is clogged up.
Old 04-29-2019, 02:24 PM
Registered Member
I think about o2 sensors replacement. Rather not fuel when I have the same symptoms using gasoline either propane-butane (LPG - quite common in EU).
MarcinK is offline
Shiffy
Ramblings
17
01-15-2006 01:57 PM
187_FAQ
12-27-2004 02:43 PM
DDT-TypeS
Ramblings
24
04-18-2004 05:22 PM
Zapata
Second Generation CL Discussion (2000-2003)
19
06-04-2003 06:13 PM
BSK181
24
08-09-2001 04:16 PM
Quick Reply: 2007 RL poor acceleration when hot
