Notices
06 RL - Garnish Assy. R FR Windshield Side - unglued
Old 03-11-2012, 11:45 AM
Registered Member
rl015's Avatar
Liked 78 Times in 64 Posts
Just last night coming back from Chicago on I-94 my wife noticed on the right side of the windshield trim piece unglued and was bit flapping; parked on the side, got out and noticed that I can place back the trim into its place but it is not as firm as the left side (driver side).
I imagine it unglued itself over the time and needs to be glued back.
Note: I believe the windshield was replaced before as the sticker says pinkelton or something like that; anyhow, it is possible that this piece just unglued or was not fixed properly when they replaced the windshield.
What is the best way to fix this? Glue it myself or go to body shop and let them handle with their glue (honestly don't see the difference but anyhow)...
Thanks All!
rl015 is offline
Old 03-11-2012, 11:52 AM
Registered Member
Legendliving's Avatar
Liked 3 Times in 3 Posts
There should be no glue involved with these pieces. The windshield fitter has broken the rather flimsy clips that hold that trim in place, or at least that's what happened to me. They have since supplied me with a replacement side fitting but I've not bothered to fit it yet as a bit of thick sticky tape wedged in the groove seems to be holding at the moment.
Legendliving is offline
Old 03-11-2012, 12:14 PM
2012 TL SH-AWD
Zelaya's Avatar
Liked 118 Times in 103 Posts
Same thing happened to me several months ago. I use 3M double side tape and it works so no more flapping when I go pass 60 MPH.
Zelaya is offline
Old 03-11-2012, 08:55 PM
Registered Member
rl015's Avatar
Did you use 3M tape the whole length or just at the spots where the fitters are. I definitely see top two were plastic and kind of look worn out / broken... bottom two look metal and pretty stable.
Thanks!
rl015 is offline
Old 03-13-2012, 02:04 PM
Registered Member
Mine was firmly fixed at the bottom, so I packed tape around the plastic molding that slots into the groove for the top 6 inches or so.
Old 03-13-2012, 02:19 PM
2012 TL SH-AWD
Zelaya's Avatar
Thanks!
My friend didn't have enought clearance so he used couple pieces. He did use 3M tape. no more flapping going over 60 mph
Zelaya is offline
Old 03-13-2012, 05:09 PM
Registered Member
rl015's Avatar
Awesome - will have to do it later!
Thanks for all the help!!!
rl015 is offline
Old 03-13-2012, 06:26 PM
Registered Member
HEAVY_RL's Avatar
Liked 982 Times in 801 Posts
Fapping going 60??
HEAVY_RL is offline
Old 03-13-2012, 09:58 PM
Registered Member
rl015's Avatar
Completed the work needed - here is the photo showing half job done ...
In yellow square I placed more 3M d-sided tape and than where the circles are I had 3M tape cover both sides (one piece tape) so when I pushed it in it stays... I reinforced this thing so there is no way it will ever flap
rl015 is offline
Old 03-03-2017, 08:36 PM
Registered Member
My_1st_Ac's Avatar
Liked 2 Times in 2 Posts
I know this is an old thread, but, both of my windshield trims (right and left) came loose at the top. The now flap when I drive. I had the windshield replaced in 2015. The OEM parts will cost me $350 at the dealership. I can't seriously pay that much money for some plastic. I can not find any used ones online, so since my car is now 12 years old, I would like to try the 3M tape method. I can not open your previous pics. I know this is a long shot, but could you post them again? I believe my only broken clips are at the top, close to the roof on both sides.
Thanks!
Teresa
My_1st_Ac is offline
Old 03-03-2017, 10:37 PM
Torch & Pitchfork Posse
TampaRLX-SH's Avatar
Liked 1,784 Times in 786 Posts
The side garnish is about $95 from DelRay OEM Parts.
But if the garnish is not broken itself, you can buy just the clips $6-7.
https://www.acuraoemparts.com/auto-p...indshield-scat
TampaRLX-SH is offline
The following 4 users liked this post by TampaRLX-SH:
Ken1997TL (03-20-2019), oo7spy (03-04-2017), projektvertx (03-03-2017), teh CL (03-04-2017)
Old 03-04-2017, 06:18 PM
Registered Member
My_1st_Ac's Avatar
Thank you Tampa!
The following users liked this post: My_1st_Ac
TampaRLX-SH (03-04-2017)
Old 03-20-2019, 09:19 PM
Ken1997TL's Avatar
Liked 2,152 Times in 1,228 Posts
Mine are popping out. Time for some clips!
Ken1997TL is offline
csmeance
Fourth Generation TL (2009-2014)
22
09-10-2018 09:15 AM
navtool.com
3G MDX Discussion (2014+)
32
01-20-2016 11:43 AM
navtool.com
31
11-16-2015 08:30 PM
Brandle34
09-23-2015 07:20 PM
Quick Reply: 06 RL - Garnish Assy. R FR Windshield Side - unglued
