one headlamp going dim
Hi,
We have a 2013 RDX Tech FWD. Tonight I noticed that the driver-side HID headlamp seemed dim and/or yellowish. I assume this is a sign that it is going bad. If so, how soon do you think it will be before it goes out completely -- hours, days, weeks, months?
The car is still under the CPO warranty, and it even has an extended warranty, but I assume this would not be covered, right?
I guess I will call the dealer tomorrow, but I thought I'd try to prepare myself for bad news. I assume these are expensive. Also, should both headlamps be replaced at the same time, or might the other one be good for quite a while longer?
Thanks for any information you can provide.
Gregg
Gregg
Carbon Bronze Pearl 2008
Hi,
Gregg
Gregg
mrgold35
If the headlight isn't covered by the warranty, you could flip/flop the bulbs. You can then determine if the bulb is just going bad or if the ballast is the problem.
Thank you both for the responses. It sounds like a failed ballast might be covered by the warranty, whereas a failed bulb would not be covered. Is that right?
How difficult is it to flip/flop the bulbs? Might I end up damaging the "good" bulb? If the headlamp is going to need to be fixed anyway, should I just let the service person determine whether it's a bad bulb or a bad ballast? Hopefully they would be honest about what needs to be replaced.
Thanks,
Gregg
Thanks,
Gregg
HID bulbs will often change color or dim before failing. In my experience a bad ballast would result in the light not coming on at all. If it is the bulb, I would recommend replacing both at the same time. They are not expensive if you don't buy from the dealer. As to the warranty, just take it in and find out. If it isn't covered, you may want to DIY to save $$$.
